603,968 active members*
1,471 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Problems with jogging...jogs a little and then stops? Hangs up while homing.
    Dec 2012
    108
    I've been very happily running Mach 3 on my Saturn router for almost a year. I have a windows laptop running smoothstepper with a CNCRouterparts control.
    I made the mistake of unhooking the laptop to take to a friends to program an Ebike speed control (not sure if it's related or not). Usually I just run Vcarve and Mach 3, but this time I downloaded one file for the programming and that's it. In the future I'll just keep this laptop as an appliance and not mess with it!
    Now when I try to jog to the home position it will move an unpredictable amount and then stop. If I try the step command for .100" it might move .030", or some other random amount. If I try to go home it'll say "homing Z axis and then just hang up.
    Any ideas? I'm dead in the water!
    Thanks for any help!
    Ward
    Dec 2013
    5720
    Re: Problems with jogging...jogs a little and then stops? Hangs up while homing.
    If you're running Windows, try restoring your computer to a time before you worked on the Ebike. That should unload any incompatible drivers.
    Dec 2012
    108
    Unfortunately there are no restore points...I guess the default condition is "off" with Windows.
    Still looking for ideas...
    Dec 2012
    108
    Actually, I think I found the problem! I have a USB MPG, and if I unplug it everything seems fine now. Maybe there was something with the routing of the wiring of the USB cable and the Laptop power cable and noise?
    I can try re-routing the cables now that I know it's not a Mach setting.
    Thanks everyone!
    Ward
  1. Fanuc 10T problems with jogging
    By an0n in forum Fanuc
    Last Post: 03-26-2021, 11:09 AM
  2. Problems with jogging. MK3
    By MrEmo in forum PlanetCNC
    Last Post: 07-13-2017, 09:41 PM
  3. Replies: 1
    Last Post: 09-18-2014, 09:57 PM
  4. Replies: 13
    Last Post: 06-25-2014, 02:21 PM
  5. Problems with Mach3 Jogging.
    By Ncrazyballa in forum Mach Software (ArtSoft software)
    Last Post: 04-30-2012, 01:27 AM
