Re: LAN comms from pc to okuma genos
hi meintjes, i am connected like that
about the network configuration, i can not help you, since our PCguy do it, and at my home my local network had been configured by some guests, so ...
however here are a few tips :
... go to the google comunities\microsoft, and ask for configurations to boost local network, specific to each operating system
... this should remove / reduce lags
... if you conect multiple pc's, operated by different guys, to a same machine, than you may encounter some conflicts when operating the machine
...... regard MD1 contect as volatile, thus nobody should complain if it's content is lost
...... create inside the cnc a folder for each guy ( = pc = terminal )
... if one guy operates more than a single pc, you should consider a syncronizer :
...... offline ( for example on an external HDD ; try freefilesync )
...... online ( try spideroak )
sync data with a pc located in another phisical place, at a certain distance from working place ( like home )
i was also told to print on paper my programs, just in case; so far i didn't
consider using total commander, with customized views for each machine; it is way faster than using windows
this is only the begining / kindly
