603,807 active members*
4,208 visitors online*
Results 1 to 3 of 3
    Mar 2018
    Spindle speed
    I've dsp 501 vfd inverter and chinese 5.5kw spindle for my router. Now how i can check at which speed my router is spinning?
    Attachment 391106Attachment 391108Attachment 391110Attachment 391112
    Sent from my SM-J710FN using Tapatalk
    35494
    Re: Spindle speed
    Jun 2011
    692
    Re: Surfacing aluminum with 2.2kw spindle. Best tool for the job?
    Quote Originally Posted by Muhammad_Haroon View Post
    How to check at how much speed my spindle is moving
    Most use a non-contact tachometer. You stick a little piece of reflective tape to the spindle shaft and the tach bounces a light beam off it and counts the pulses.
  1. Replies: 0
    Last Post: 06-10-2016, 03:08 AM
  2. Fanuc AC Spindle Drive speed does not match S-code speed
    By serickson in forum Spindles / VFD
    Last Post: 10-13-2014, 01:18 PM
  3. Replies: 1
    Last Post: 08-02-2013, 10:07 PM
  4. mach3 spindle dro not working, spindle speed changing while jogging and running code
    By jasminder in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2011, 07:12 AM
  5. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
    By peter.blais in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2006, 09:29 AM
