587,221 active members*
3,092 visitors online*
Results 1 to 11 of 11
    Jan 2018
    5
    mach 3 dead pc
    my older pc that I run my mach 3 mill on died looking to replace it but doesn't look like u can buy anything new to work with it? any ideas??
    Thanks Ryan
    Jul 2017
    42
    Re: mach 3 dead pc
    I ended up finding a used computer on craigslist that had Win 7 installed. It's been working fine.
    35538
    Re: mach 3 dead pc
    If you add a motion controller like a UC100, you can run Mach3 on any modern PC.
    15362
    Re: mach 3 dead pc
    Quote Originally Posted by outboardsbyryan View Post
    Thanks Ryan
    I just brought a RCA tablet to try, has the latest Windows 10 on it, with the UC100 works like a charm, I loaded the Mach3 software and the UC100 plugin onto a Micro SD card which this tablet has a slot for
    I will add other controls as well to see how far we can take one of these Tablets
    Mactec54
    Jan 2018
    5
    Re: mach 3 dead pc
    thanks guys!!
    Dec 2017
    77
    Re: mach 3 dead pc
    Buy one of these and use any PCI-e slot:
    https://www.ebay.com/itm/222897270029
    15362
    Re: mach 3 dead pc
    Quote Originally Posted by jo_ky View Post
    Most of the computers with the PCI-e slot are not supported for running cnc control software, about 1 in 10 you may get to work, so in other words don't waste your time, people have had plenty of time to change from Parallel port computers
    There is still mother boards out there to build a new computer if someone needed to have a Parallel Port, they are easy to build a simple computer like this
    Mactec54
    Dec 2004
    95
    Re: mach 3 dead pc
    Any source for this other than the top of your head?
    Dec 2017
    77
    Re: mach 3 dead pc
    Yeah, I believe you're thinking of USB based parallel adapters.
    15362
    Re: mach 3 dead pc
    Not at all, I build computers for machine controls I know what works and what does not
    Most are using lap top for there machine control, which some have Parallel Express Card port, this also is a problem, more so than using a PCI card as you suggest
    Mactec54
    Dec 2017
    77
    Re: mach 3 dead pc
    Well, I'm sure there are a lot of weird drivers with weird compatibility issues, out there. I didn't mean to say that you don't know your stuff. But as far as Mach 3 and PCI-e parallel cards goes, I still maintain there shouldn't be any incompatibilities, as long as the card supports EPP.
    I also agree: "people have had plenty of time to change from Parallel port computers." There are better ways now.
  1. Check for dead stepper (or: dead driver; stepper-/input-related?)
    By dbtayl in forum Stepper Motors / Drives
    Last Post: 07-05-2014, 02:04 PM
  2. Series 1 BOSS 5 X Axis Dead, still dead after new transistors
    By keebler303 in forum Bridgeport / Hardinge Mills
    Last Post: 02-01-2014, 04:27 PM
  3. Mazak M5 DEAD BATTERY -DEAD CONTROL
    By tired_iron57 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-06-2012, 07:35 PM
  4. Fanuc 0 dead screen ... dead control?
    By Noss Machine in forum Fanuc
    Last Post: 01-24-2009, 04:03 PM
  5. Confused: Mach Turn, Mach Mill, Mach 2/3 ?
    By CanSir in forum Mach Software (ArtSoft software)
    Last Post: 02-16-2007, 11:41 AM
