603,964 active members*
1,644 visitors online*
IndustryArena Forum > CAM Software > Mastercam > acme with grooving tool 2d or 3d?? help
Results 1 to 7 of 7
    Apr 2007
    12
    I have version 8.1 and am trying to do an 5 inch acme thread 1 start with a grooving tool, is this possible with simple 2d or do i have to create a surface , if anyone has experience help pls.
    Apr 2007
    12
    Hi guys I thought i better send you a copy of what i have drawn, ive also done a surface of the acme but dont know how to machine it and if possible.
    the tool i have to use is 8mm grooving tool.
    Attached Files Attached Files
    Sep 2006
    You can rough it with the groove tool, but you will need to grind a tool in the acme form or get an insert made for cutting an acme thread. Getting an insert is the easiest way. I just use the insert and cut the whole thread without roughing it in though. Your tool path looks fine.
    Joe
    Apr 2007
    12
    Thanks joe,
    But i think i might have to write it manually as the tool will have to be a groove tool. Boss wants it that way.
    If you have any other suggestions would be good.
    Hey isnt it good that you can get help/advise whatever you wanna call it from around the world.
    I just discovered it, before i use to bother my college teacher all the time but now that im not studying its better this way.
    Jan 2006
    4396
    Quote Originally Posted by jone View Post
    Thanks joe,
    What your trying to do is going to be very tricky without the right tool. PM cadcam, Mike Mattera, or Matt Berube. They will know how to do this in MC.
    Cheers!!!!! and welcome to this Community:cheers:
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Apr 2007
    12
    Thanks toby,
    Hey what you mean by PM etc etc.
    Regards jone
    Jan 2006
    4396
    Thanks toby,
    Regards jone
    A PM is a Private Message. You can do this from the User Control Panel of from the Buddy List that you can create.
    The user control panel is labled User CP in the top menu
    Here are some screen shots.
    Cheers!!!!!:cheers:
    Toby D.
    Schwarzwald
  1. Acme Internal Thread 1 ½ - 0.250P-2.000L-ACME-2G-LH (8 START) Help
    By pandiyan.innova in forum Community Club House
    Last Post: 11-16-2006, 12:47 PM
  2. Fanuc G75 Grooving Cycle post processor
    By rk176 in forum FeatureCAM CAD/CAM
    Last Post: 11-07-2006, 02:00 PM
  3. ID Acme threading tool needed
    By 2_jammer in forum MetalWork Discussion
    Last Post: 04-19-2005, 03:08 AM
  4. Cutoff/grooving problems
    By july_favre in forum Mini Lathe
    Last Post: 07-30-2004, 06:42 AM
  5. what acme tap do I need for the Enco ACME rod?
    By AJ_Mac2001 in forum DIY CNC Router Table Machines
    Last Post: 03-08-2004, 02:24 PM
