587,773 active members*
3,185 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > USBMotionCard STB4100 & VFD wiring ?
Results 1 to 2 of 2
    Mar 2017
    3
    I did search the web, this section and the rest of the forum, but I can't find an answer to this. And I'm not an electronics guy, so please keep it simple.
    I got an Emerson Control Techniques Commander SK VFD (not hooked up at all yet) that I'd like to hook up to the USBMotionCard STB4100 and control it through Mach3 once I know it's functioning properly using the keypad on the VFD.
    But here's the part I am having trouble with, it's the wire(s) hookup from the USBMotionCard STB4100 to the VFD because they are marked different on both units.
    do I have to connect it like that
    VFD STB4100
    T1 COM
    T3 DAC
    T4 O1
    Any help would be appreciated
    Jan 2007
    626
    Re: USBMotionCard STB4100 & VFD wiring ?
    Not seen that VFD but this diagram was on page 142 of the manual.
    Attachment 393494
    T4 looks like your 0-10v speed signal from your motion card.
    You may need to enable the drive with B4 before a signal on B5 will allow it to start.
    Have a play on the bench and get it working before you wire it in. Use some jumpers and a DC voltage to set the speed.
  1. Mach3 USB Motion Card STB4100 - Best FC300
    By supernichi in forum Mach Lathe
    Last Post: 04-16-2018, 09:58 PM
  2. Wiring a YL600-2S-2K20 P110V to STB4100
    By profes61 in forum Spindles / VFD
    Last Post: 03-22-2018, 02:53 PM
  3. STB4100 rnr-motion router cnc problem
    By by_yasar in forum Mach Software (ArtSoft software)
    Last Post: 03-24-2017, 02:11 PM
  4. Help! -STB4100 rnr-motion router cnc problem
    By by_yasar in forum Mach Lathe
    Last Post: 03-22-2017, 06:56 AM
  5. Mach3 USB Motion Card STB4100
    By Poppey in forum Mach Lathe
    Last Post: 01-01-2017, 12:41 PM
