587,657 active members*
7,579 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco KM3 3 phase to single phase conversion
    Mar 2024
    12
    Hi, I have Hurco KM3 and I wish to convert it to single phase.
    At the moment I have chosen the VFD route, utilise the servo side of the machine to single phase and use the VFD to run the 3 Horsepower spindle.
    Has anyone gone down this route, and any advise on this or different options
    thanks for any help on this subject
    macdave
    Apr 2009
    21
    Re: Hurco KM3 3 phase to single phase conversion
    Ok, where I am currently,
    I have connected single phase 240V to L1 Line in and Neutral 0V to L2 Line in and ignored L3 as it is connected to the 3 phase spindle and flood coolant which is 3 phase. The control has booted up but when I get to the Power on there is no flashing light and I cannot calibrate the machine.
    Any ideas anyone, thank you.
    Nov 2013
    4541
    I rather suspect that there is an interlock that prevents the control from operating until the three phase components are properly powered.
    It could be something like a phase rotation/phase missing relay. The affirmative output of that relay is required before the control will complete its boot up.
    Craig
    Apr 2009
    21
    Hi Craig,
    thank you for that, ill see if I can find a drawing showing relay connections from the spindle. I had disconnected the spindle and the coolant pump, both 3 phase, from the relays to try and bypass that. From your thoughts I made need to put a feed to a relay that would normally come from the circuit of the spindle. I presume you looked at the wiring schematic above and couldn't see any thing that might do that.
    Dave
  1. Replies: 29
    Last Post: 02-12-2022, 09:20 PM
  2. Replies: 1
    Last Post: 04-18-2020, 04:35 AM
  3. Robodrill 7.5hp spindle. Single Phase Power input No Rotary Phase convetor doable?
    By whiteriver in forum CNC Machine Related Electronics
    Last Post: 01-05-2017, 09:01 PM
  4. Replies: 2
    Last Post: 09-24-2015, 07:04 PM
  5. Replies: 12
    Last Post: 10-13-2009, 03:53 AM
