587,220 active members*
2,859 visitors online*
Results 1 to 9 of 9
    Jun 2012
    153
    opto-isolator / limit sw advice.
    I have spent most of the day digging the best way to use an opto-isolator for a limit switch and I've come down the this:
    Attachment 416670
    I'm running GRBL modified for STM32F411RE. The circuit will be duplicated for the three limit switches ( more accurately used as home switches ) and a Z-probe.
    The main power supply is coming from an HP printer switched mode PSU, 32V @ 2A. This is feeding one of my stepper motors via an STM PowerStep01 IHM031 demo board. Since it will be a bit noisy, I added a linear regulator to step it down to a smooth 12V.
    The detector side of the opto is powered from the STM32 Nucleo ( Arduino format ) MCU board. Light load on the onboard 5V regulator is allowed.
    The STM32F411 has Schmitt triggered inputs, so the RC filter should provide some debounce and noise protection.
    I got to wondering whether the 7812 was necessary or whether it would be better running the switches directly from 32V to get higher noise immunity.
    I've done a fair bit of electronics but I've not had experience in this kind of machine environment.
    Can anyone who is more familiar tell me if this looks credible. Any other comments or things I've got wrong?
    TIA.
    [EDIT] Just noticed I have two R2s there. Please regard the output of the the 817 as being connected to R3.
    Mar 2017
    411
    Re: opto-isolator / limit sw advice.
    I think your circuit looks like it would work.
    However, for the input low pass filter, R2 doesn't do anything but divide the voltage of the incoming signal. And, you don't need the power supply to create the 12 volts at the switch. You could put the 36 volts directly to the switch. You would have to work out new resister values though.
    Finally if your controller or BOB has a input pullup resistor, you don't need the +5V supply.
    Mar 2017
    411
    Wait, I may have spoken too soon.
    Are the switches Normally open or normally closed?
    Jun 2012
    153
    Thanks Max. The i/p can be configure as pull-up , I had not looked at it like that. Seems to make sense.
    I don't think you are correct that R2 will divide the voltage. The photodiode has a max forward voltage drop of 1.2V so will effectively short out r2 once it starts conducting. R1 is a current limiting resistor.
    R2 is there to ensure that C4 discharges once the switch re-opens.
    Part of my question was the merit of having the linear regulator or not. Sure, I could just connect to 32V but that is likely to be noisy since it is feeding the motor driver cct. Having a regulator with a substantial voltage drop should clean that up a lot.
    N/O.
    Mar 2017
    411
    Yes, I spoke too soon. What about this one?
    First, if you can keep from sending power out to the switch, that might be good. Eliminate shorts of high voltage if a cable gets pinched. The switch can just provide a short to ground to generate it's signal. Using a Normally closed switch is also a good idea so that a broken wire or disconnected cable will look like an activated limit switch so you will know there is a problem right away.
    Regulating the voltage down, is good, but the RC filter at the input will do the same thing.
    Doesn't the Arduino board have a 10K pullup on the input pins?
    Mar 2017
    411
    Let me think out loud about this for a sec.
    Sitting still, the switch will be closed (NC switch) and current will flow from 36V to ground through R1 and C1 will be discharged. When the switch hits the limit the current through the opto will stop and C4 will begin to charge. So, this might work however C4 would have to be a 36Volt cap. Not so easy.
    Maybe just stick the RC filter on the output of the opto? Then you have smaller capacitors.
    Oh, wait. You said that the switch is NO. So you will not be able to detect a broken cable. But it still works the same.
    Jun 2012
    153
    SW1 can be either N/O or N/C.
    It's not an Arduino. The pull ups are 40k. Are you still suggesting dropping the output resistor and using just the internal pull-up?
    Good point.
    Mar 2017
    411
    More thinking...
    What was the time delay of the RC circuit? Will that reduce the accuracy when you use the limit switch for homing?
    Do you really need to debounce a limit/home switch? It's not like an encoder where a noisy signal looks like extra pulses. The switch bounce will not occur until you are at the limit so any signal however small means STOP. I bet the controller will use the edge as the trigger. I have mechanical switches on my mill and none of the signals are debounced and I have not had a problem. I also use the same circuit for my probe and it is not debounced.
    Jun 2012
    153
    I did say I'm looking for a bit of noise immunity too.
    Current RC is 0.1ms, the mechanics are not going to move far in that time. Modern, current limiting, stepper motor drivers do a lot of h.f. switching which I have seen folks finding it being picked up on limit switch cabling.
    I think I will go with your switch to ground configuration, for the reasons you give, plus it is compatible with a N/C Hall effect proximity detector I may want to use instead, if the switches are not reliable / accurate enough.
    Thanks for you comments.
  1. Need Optocoupler/Opto-isolator
    By lingo124 in forum CNC Machine Related Electronics
    Last Post: 06-23-2013, 05:44 AM
  2. Need help in opto isolator circuit!
    By evander in forum CNC Machine Related Electronics
    Last Post: 04-07-2010, 06:25 AM
  3. Opto-Isolator problem G201 ?
    By Clyde in forum Gecko Drives
    Last Post: 08-20-2008, 12:09 PM
  4. Opto-isolator problem?
    By Me2 in forum Gecko Drives
    Last Post: 10-27-2007, 02:31 PM
  5. LPT Opto isolator Circuit Schematic
    By graphpix in forum CNC Machine Related Electronics
    Last Post: 02-20-2005, 11:13 PM
