587,577 active members*
3,317 visitors online*
Results 1 to 3 of 3
    Jun 2017
    143
    TNGv2 Dialog positioning
    While setting up TNGv2, getting all the buttons/scripts etc right I did it on a computer in the office where I have a large 4K monitor. Once I got everything right I then copied the profile to the actual machine with the CNC Mill attached which only has a 1920x1080 monitor. Everything worked fine except that the dialogs (settings, script editor etc) remembered there position and size on the 4K monitor, not a problem for some as I could see some of the dialog so could drag it back onto the screen. But my script editor dialog I must have had completely on the right hand side of the screen and once I opened it I could not see any of it. It might be an idea to do a sanity check on the position of the dialogs when opening them (ie. if the top left of the dialog isn't on the screen then reset to default position/size).
    Cheers
    Simon
    Mar 2017
    1329
    Re: TNGv2 Dialog positioning
    Menu "View/Reset Windows"
    I'll also add some additional sanity checks for next release.
    Jun 2017
    143
    Thank you. I didn't notice that option.
  1. TNGv2 for Mac OSX
    By tantemay in forum PlanetCNC
    Last Post: 08-24-2023, 07:12 PM
  2. [TNGv2] - Expr.txt
    By PlanetCNC in forum PlanetCNC
    Last Post: 05-29-2023, 06:20 PM
  3. [TNGv2] - 2019-11-08
    Last Post: 11-09-2019, 02:15 AM
  4. [TNGv2] - 2019-10-28
    Last Post: 10-28-2019, 04:52 PM
  5. [TNGv2 - API]
    Last Post: 10-27-2019, 11:23 PM
