603,793 active members*
2,845 visitors online*
IndustryArena Forum > CAM Software > CamBam > Measuring in CamBam
    May 2009
    14
    Measuring in CamBam
    Is there any way to measure some things in CamBam? Like select two point and get a size in mm?
    May 2008
    266
    Yes, there is a measure function under Tools on the menu.
    Martin.
    May 2009
    14
    I can't find it. I'm using the free version
    Feb 2005
    521
    Quote Originally Posted by Gilius View Post
    Sorry Gilius,
    The measure tool was added to CamBam plus a while after the latest free release.
    You can install CamBam plus and the free version on the same machine.
    In most cases, the plus version will read files generated in free CamBam.
    After the evaluation period has expired, CamBam plus will continue to work in that you can open and edit files (as well as use the measure tool), but not create g-code from them.
    I hope this helps.
    www.cambam.co.uk
  1. what is CamBam?
    By cncadmin in forum CamBam
    Last Post: 05-02-2009, 01:41 AM
  2. CamBam Plus (DXF files)
    By Switcher in forum CamBam
    Last Post: 11-17-2008, 07:27 PM
  3. Need Help With CamBAM
    By Ponchibego in forum CamBam
    Last Post: 08-01-2008, 03:49 AM
  4. CamBam is going to Texas ! (Oct 20-21)
    By 10bulls in forum CamBam
    Last Post: 10-04-2007, 11:08 AM
  5. Will CAMBAM run in Win 98 ?
    By epineh in forum CamBam
    Last Post: 08-03-2007, 06:50 AM
