603,975 active members*
3,406 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > newbie question - help is appreciated
    Jul 2007
    Hey Guys-
    I am looking to buy a desktop cnc router to cut 1.5 mm lexan and wood up to 1 inch thick. The pieces will generally be pretty small. I was looking at a Roland EGX-600 engraver. Is an engraver the same as a cnc router? I was looking for something very easy and straightforward.
    I have restrictions in terms of size, weight an noise. Also, to cut stuff that thin/small, I don't need a big machine.
    Any help and/or suggestions would be greatly appreciated.
    Thanks.
    Aug 2005
    828
    I think this will a better deal for the money:
    http://www.circuitspecialists.com/prod.itml/icOid/9171
    Here is thread about:
    http://www.cnczone.com/forums/showthread.php?t=38854
    Just buy a nice high speed spindle for that router and you will have a quiet powerful machine.
    The roland is a much lighter duty machine, and if some thing breaks it will cost a pretty penny to fix it, but with the other router the most expensive drive part is under $150. And you can use Mach3 software: http://www.artsoftcontrols.com/
    It's simple and priced correctly. This is the machine controller I started with and if it wasn't for Mach I would not have started at all, this cnc stuff was intimidating me for a long time
    Dennis
    Jul 2007
    thanks
    thanks Dennis-
    I appreciate the answer. Would I have to put it together myself? How would I know which spindle to get and how to connect it? I really don't know much and was looking for something that is "plug and play". Are there any books or threads for "CNC for Dummies"?
    Also, I get to Clearwater FL a couple of times a year, and I'm not a scientologist!
    Thanks again,
    Tarsier
    Aug 2005
    828
    Quote Originally Posted by tarsier View Post
    thanks Dennis-
    Tarsier
    There is plenty of them around here.
    The CNC9000 router comes with everything you need except a computer, spindle and cnc software ($160).
    The type of spindle will depend on what you will be doing with the machine most of the time?
    Plus with this machine you will learn a lot and be able to fix it your self if you crash it in to some thing.
    I'm just very DIY type so I encourage others
    Dennis
  1. new to hobby, answers appreciated
    By vietrat in forum Mastercam
    Last Post: 10-04-2007, 05:30 AM
  2. multicam3000 errors-help appreciated
    By calgary in forum Commercial CNC Wood Routers
    Last Post: 06-14-2007, 02:38 PM
  3. Advice greatly appreciated for a Noob.
    By Kammo1 in forum DIY CNC Router Table Machines
    Last Post: 06-05-2007, 09:13 PM
  4. Starting knee-mill retrofit. Your input appreciated.
    By jamma in forum Uncategorised MetalWorking Machines
    Last Post: 03-01-2007, 05:41 PM
  5. any info is appreciated
    By bthomps5 in forum Mastercam
    Last Post: 04-12-2006, 04:17 AM
