603,344 active members*
3,594 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Good source for motor replacements of Series I stepper motors?
Results 1 to 2 of 2
    Oct 2006
    90
    I have been fighting with an X axis final drive problem that has led me to suspect the X motor. Are there any good suppliers that have the right type of motors that could be used in conjunction with the original Y and Z motors without causing any problems? I should mention that I will need something that is compatible with Hillbilly's break out board. TIA,
    Ian
    Oct 2006
    42
    These things show up on the E-bay auction site from time to time; that's where the motors from my machine went when I converted to servos. I don't see any on auction at the moment, but this guy lists them in his "E-bay store":
    http://cgi.ebay.com/Bridgeport-Stepp...QQcmdZViewItem
    $299 seems kinda spendy, though. If I recall, all three of my motors went for that total.
    Disclaimer: I have never done business with this seller.
    I should add, I believe that the X and Y motors are interchangeable, so you should be able to swap motors and see if the problem follows the motor before you spend mony on a replacement.
    Dennis
  1. Stepper motors in series?
    By MrRage in forum Uncategorised MetalWorking Machines
    Last Post: 09-14-2005, 09:10 PM
  2. ware is a good place to buy stepper motors ?
    By Biggermens in forum Stepper Motors / Drives
    Last Post: 10-29-2004, 01:26 AM
  3. Fruit Machine Stepper Motors - Any Good?
    By koslaz in forum Stepper Motors / Drives
    Last Post: 10-22-2004, 08:45 PM
  4. Good stepper motors w/cnrlr at great prices
    By ccm in forum DIY CNC Router Table Machines
    Last Post: 08-07-2003, 06:53 PM
  5. WTD: source for big stepper motors
    By dmoore3008 in forum DIY CNC Router Table Machines
    Last Post: 05-03-2003, 09:27 PM
