603,939 active members*
2,599 visitors online*
Thread: end mills?
Results 1 to 3 of 3
    Mar 2007
    31
    end mills?
    I am trying to find a 1/16 end mill that will be long enough to go thru 1/4" aluminum .
    Anyone have any suggestion where i could find a couple mills at?
    Apr 2003
    540
    Re: end mills?
    You must not have searched much. 1/4in depth of cut is about average in 1/16 mills. You can get them with longer depth of cut and longer shanks. Just do a seach on ebay or the web. !/16th is pretty small for actually cutting out parts and your speeds and feeds need to be set carefully to avoid snapping the mill. If at all possible cut with a larger diameter mill and then finish any small pockets or tight profiles with the 1/16th. A one or two flute with a high helix will work best with aluminum. Just search for "end mills for aluminum".
    Apr 2012
    90
    Re: end mills?
    mscdirect.com they are pricey if you don't have coupon code but will typically have whatever you need.
  1. New Mills Are In!
    By Charter Oak in forum Charter Oak Automation Support Forum
    Last Post: 08-26-2013, 05:27 PM
  2. Pcb End Mills
    By djh82uk in forum Benchtop Machines
    Last Post: 10-07-2007, 01:16 PM
  3. FX Mills
    By rickyt in forum Fadal
    Last Post: 04-09-2007, 10:10 AM
  4. Bug Mills
    By Zumba in forum Community Club House
    Last Post: 12-16-2006, 03:23 AM
  5. Face Mills intstead of end mills
    By balal in forum MetalWork Discussion
    Last Post: 07-01-2006, 06:35 AM
