587,999 active members*
5,128 visitors online*
Thread: SV006 alarm
Results 1 to 6 of 6
    Apr 2003
    31
    SV006 alarm
    Good Day
    I have a Wasino LJ63 M lathe that I am running off a phase converter.
    when I am Running a program and the machine rapids from the last line to G54 before it starts next line of code I get a Alarm SV006 velocity power to low.
    Is it possible to change parameters to lower the ramp up,or do I do have to change drive board .
    I have 234 volts going into machine on two legs and wild leg is 237v
    I also have 60 amps going to converter.
    Anybody got any solutions
    Thanks in Advance
    Edit / DeleteEdit Post Quick reply to this messageReply Reply With QuoteReply With Quote Multi-Quote This Message
    Re: SV006 alarm
    Control type?
    Apr 2003
    31
    Re: SV006 alarm
    Fanuc 10 T
    Nov 2007
    364
    Re: SV006 alarm
    Dont go into G00 for the line just leave it in a fast feed rate for now under a G01 ------Must be an issue with accel and decel that has had the same parameters for a long time so maybe some type of wear or lack of oil causing higher voltage/amps requirement ?------Should get you running fingers crossed-------just make sure well clear of all work piece
    Re: SV006 alarm
    Parameter 1620 is the Time Constant (Acceleration/Deceleration) for rapid traverse. This parameter is set in milliseconds. The larger the value the longer it takes to get up to speed.
    Apr 2003
    31
    Re: SV006 alarm
    thanks i will try that
  1. Hyundai Kia SKT 100 turret amp alarm AL 62 (Alarm 2062)
    By roboticist in forum Hyundai Kia
    Last Post: 02-16-2022, 06:01 AM
  2. Replies: 4
    Last Post: 05-03-2019, 08:58 PM
  3. Component level repair of Fanuc A06B-6058-H224 SV005 SV006 and SV0023
    By StepDIR in forum Machinery Manuals / Brochures
    Last Post: 11-01-2016, 12:50 AM
  4. Replies: 6
    Last Post: 03-13-2013, 03:32 PM
  5. Replies: 4
    Last Post: 06-12-2009, 09:15 PM
