603,874 active members*
6,709 visitors online*
Results 1 to 3 of 3
    Sep 2007
    KL5056 runs one way only
    Hello.
    I've got KL5056 drivers and a KL5042 driver.
    When using the KL5056, the motor rotates one way only.
    When I switch off the system and I unplug the green conectors from the KL5056 and I plug a KL5042 on its place, (so the wiring are the same), the motor rotates fine in both directions once switched on the system again.
    I've tested different current and microstep settings with the same results. I've tested bipolar series and bipolar parallel wirings too.
    There is no way to get the motor rotating two ways when using the KL5056drivers.
    Can anybody suggest any help?.
    Thank you.
    Aug 2006
    225
    Dont know if this will be of any help since i do not have a system like yours, however, i recently went through similar problems with a HobbyCNC board. If they are even semi decent im sure they will have their own built in protection circuit, which was like mine. My protection circuit had tripped and caused the same problem so see if there is a fail safe and if so try the reset mode, like switch on-off-on-off and leave for a 5min and try that. I recommend though getting in contact with seller obviously and ask them about it as reset mode will no doubt be different and this particular method could cause problems.
    Like i said im not too sure about this system nor if this will help you what so-ever but if by any chance you have something similar to me it worth a shot.
    Daniel
    This is the test procedure
    Pls check the attached test procedure if you still have question
    www.kelinginc.net
    Attached Files Attached Files
  1. bigger motor runs, little ones don't...
    By killer_cobra in forum Stepper Motors / Drives
    Last Post: 04-01-2007, 02:30 AM
  2. runs excellent with the vampires
    By ged in forum Mach Software (ArtSoft software)
    Last Post: 03-17-2007, 04:56 PM
  3. Runs/Walks Like Deere!
    By Switcher in forum RC Robotics and Autonomous Robots
    Last Post: 01-20-2007, 03:23 PM
  4. demo version 1.84.001 runs at 35,000 Hz
    By TMaster in forum Machines running Mach Software
    Last Post: 04-28-2006, 12:57 AM
  5. X3 Mill just runs by it self
    By replicapro in forum Uncategorised MetalWorking Machines
    Last Post: 08-20-2004, 05:32 PM
