603,784 active members*
18,011 visitors online*
Results 1 to 2 of 2
    Dec 2024
    C0 baby lathe cnc conversion
    Hi guys just a new member here (although been looking at the site a few years).
    Currently converting a c0 micro lathe to cnc. Got the z axis done ok using a ballscrew but the X axis causing me a nightmare!
    The saddle is so small to fit a ballscrew through I tried an 8mm T8 leadscrew assembly but the backlash is horrendous.(around +-0.25mm)
    It's really difficult to find an 8mm ballscrew setup online so was wondering if any of you guys have any design ideas apart from machining out the saddle which I want to avoid.
    Thanks.
    Re: C0 baby lathe cnc conversion
    Quote Originally Posted by Dj863 View Post
    Thanks.
    Maybe you can consider adding an anti-backlash nut assembly.
    Which is designed to minimize backlash by preloading the nut against the leadscrew.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
  1. Best CNC Lathe Conversion ??
    By CPatten in forum Bridgeport / Romi Lathes
    Last Post: 02-27-2020, 06:48 AM
  2. C4 Lathe CNC Conversion
    By compunerdy in forum Benchtop Machines
    Last Post: 11-26-2012, 07:26 PM
  3. 7 X 12 CNC Lathe conversion
    By fragger6662000 in forum Mini Lathe
    Last Post: 12-01-2009, 09:18 PM
  4. My CNC Lathe Conversion
    By acondit in forum Videos
    Last Post: 10-18-2008, 04:20 AM
  5. CNC lathe conversion (again, sorry!)
    By kong in forum Uncategorised MetalWorking Machines
    Last Post: 03-27-2004, 08:06 PM
