Please excuse the ignorance with this question but I'm glad I found this site and just registered.
I'm a disabled vet trying to keep my brain going, so I reached into the I'll be an idiot bucket and now I'm building my 4th machine.
The other three were simple. Step motors, Mach3, Gecko 203v drives and a PMDX-122 board. All worked great.
The machine I'm building now is a high precision Swiss with Parker servos and Gemini drives that take step and direction.
Will also have a 3kw Parker servo that needs to run in velocity mode (I believe) for the spindle, but I need to do single point threading with this machine.
I want to use Mach4. I know that I need to go from the PC to the BOB (which I can't figure out which one I need yet either) Steve at PMDX can never be reached.
But from the BOB, I need to tie that into the servo drives which use an old parallel port. I think that I need to go from the BOB to something like this, correct?
EBAY - Parker GEM-VM50 with Mach3 Breakout Board Adapter Cable - Gemini Servo Drive CNC - - eBay item number:326260345469
But the ones for Mach4 - Which I have.
Then from there, tie into the drives.
One, is this correct?
Two, how do I go from the PC to the right BOB and what would you recommend for a BOB to the adapter, and anything else I might need to make this work?
Any thoughts?
I really appreciate your time and help,
Hope you're all having a great Memorial weekend!
Thanks,
Brian
