587,349 active members*
3,218 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > NEED HELP: 3040 cnc/Mill possebol Ground Issue??
Results 1 to 3 of 3
    Hi
    A did buy this machine from China zone back in 2020 but has just been standing there until now because of corona
    but desided to start it up now and have got myself a lot of surprices fist issue was that the spindel did not start then the end limit switches did not work and now the emergensy switch to is not working and the probe to allmost everything is not working A have come to an spot where a belive that this is about an ground problem and it is all conected to together ??
    Is there someone who can help me out solwing this issue?? it has an (4 aksis) MKS4-V USB motions card and an MK100 2S1.5G-Dk inverter belive the ground issue is within these 2
    thx
    Dec 2003
    24223
    Re: NEED HELP: 3040 cnc/Mill possebol Ground Issue??
    Do you have the machine drawings for the M/C?
    It sounds like it could be some power source missing somewhere ?
    Albert E.
    Hi
    Now a actualy figured out what the problem was it was completly diffrent pins and ports that needed to be set in config in mach3
    The manuals a did get from them how to set up the setup/config in mach3 for the machine to work was wrong only setting for stepper motors was correct.
    so a had to open the control box to see how the breaking board was connected/wired and then to change all setups in inputs/outputs and spindel setup after how it was wired so now all things are working
    many walls to breake down until a figure out how to make this machine start workingbut on the way a have learned quit a lot of new things
    A belived that 2 in the begining that this was the issue that it migth be an power source missing somewhere??but it was acyualy not only setup/config correctionsand voila one after another problem solved just clicked in and started working
    It is very easy to fall into the trap many places and very easy to get confused to work withanyway if you got misleaded from the start like a did here
    thx for asking
