Re: Upgrading my CNC DIY Lathe just need a couple of answers please.
My two cents...for a small lathe like that, you'll probably be using higher R PM's more than slow ones, but having said that, I think a sheave ratio to achieve the speed you've listed would be good. You can pick a middle of the road HZ (+) on your drive to get you those desired speed parameters, then be able to drop some RPM as well as over-speed the drive for anything higher...they can easily tolerate 120 Hz.
Regarding your cross slide/compound changes using linear rails, if you have room for that modification, I think it's a great upgrade.
Stuart
"THE GRIZZ" photo album - https://goo.gl/photos/yLLp61jooprtYzFK7
Youtube - https://www.youtube.com/channel/UCT2lq9obzEnlEu-M56ZzT_A
