603,807 active members*
3,164 visitors online*
IndustryArena Forum > Community Club House > Mentors & Apprentice Locator > Looking for Mentor, assist in setting Z axis auto zero
Results 1 to 3 of 3
    Sep 2003
    1490
    Need assistance in setting up Z axis auto zero.
    Mach3, Warp9 SmoothStepper ESS, BOB C25S, Gecko 540 stepper driver.
    15 year old scratch built CNC, linear rails, Ball screws.
    Need some help in configuring Z auto axis zero, wiring in Mach3 and BOB,
    Instructions from: guruBrew YouTube.
    BOB: wire one to PIN 15,
    Wire two to ground
    PORTS AND PINS: PORT 2, PIN 15, Active low. SAVED AND RESTART
    The digitizer light should light when wires are touched, but it is lit all the time.
    What am i doing wrong?
    Apr 2004
    5950
    Re: Looking for Mentor, assist in setting Z axis auto zero
    If the wires touch and conduct electricity between themselves by doing so, wouldn't that be "active high"? If it's lit all the time, with them disconnected and not doing anything, that would be the "low" position, no?
    Andrew Werby
    Website
    Apr 2022
    148
    Have you set it as “probe in” pin.
    In Mach3 you can use autoset when you define your pins, it automatically finds and set it up ( port and pin) when you momentarily connect it.
    I think it has to be define as “digital IN” pin other way it wouldn’t work
  1. Auto laser setting
    By dobrun2004 in forum Redsail Laser
    Last Post: 06-08-2018, 04:48 AM
  2. Nc studio z axis auto tool setting and more
    By 82machinist in forum Chinese Machines
    Last Post: 05-22-2017, 07:33 PM
  3. Semi Auto tool setting and Auto xyz
    By shujaa in forum Mach Software (ArtSoft software)
    Last Post: 03-16-2017, 01:29 PM
  4. Looking for a mentor to assist in Minneapolis
    By AZ Burns in forum Mentors & Apprentice Locator
    Last Post: 11-09-2010, 05:49 PM
