603,377 active members*
3,649 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > EdingCNC > Relay activation from Aux2 (open collector) startup state
Results 1 to 1 of 1
    Apr 2020
    15
    CNC760 board + relay board from cnc4pc
    My Aux 2 relays (two off of one output) are open collector, they energize upon startup, then will follow the spindle command. Temporarily I have set it up to be a closed circuit when the relay is not-activated. These control the spindle activation and spindle cooling air. This means when I power the board down, it activates the spindle/air for 1 second before losing power.
    Now moving to a relay for the spindle release (ATC). This one is more delicate, I can't have it throwing tools on startup or shutdown. How can we determine that the board shall not activate the output until everything is on, and it's asked to?
    Thanks,
    Attached Thumbnails Attached Thumbnails 20240301_213837 (1).jpg   20240303_202755.jpg
  1. Relay for dust collector
    By viroy in forum CNC Machine Related Electronics
    Last Post: 12-23-2023, 06:52 PM
  2. 24Vdc Solid State Relay not the same as mechanical relay??
    By cjchands in forum CNC Machine Related Electronics
    Last Post: 11-10-2010, 07:40 AM
  3. Using a solid state relay as a main stop relay
    By garagefela in forum CNC Machine Related Electronics
    Last Post: 02-26-2010, 11:27 PM
  4. solid state relay question
    By aegfurn in forum CNC Machine Related Electronics
    Last Post: 02-24-2007, 04:09 AM
  5. Solid state relay
    By N4NV in forum CNC Machine Related Electronics
    Last Post: 05-07-2006, 06:19 AM
