Originally Posted by
the_gentlegiant
Hi Hardyharr,
Okay, I guess you've got a way to go after all. To start, according to your attached parameter file, you have many of your servo motor parameters set incorrectly. I've attached a corrected file. Still, keep your backup. I can see you're running a6/2000's on your X and Y axis and an a12/2000 on you Z. Where did you get the parameters for your 4th axis? If they were already on the control, it could be that the previous owner had a completely different motor installed. Note that I think when you enter in the motor type no. 8, the control fills in a bunch of the rest. Can't remember. Also, and I always have trouble with this, according to my param book you can try a AMR of 00000000 and a CMR of 2.
I don't think you completely understand the decel homing thing. To home the axis, the trip dog has to contact the switch, and then when it falls off the switch, that's when the grid starts counting. Meaning it's a on/off (or potentially off/on) thing it's looking for before it starts counting. You adjust your grid shift parameter amount to get the thing to home dead on. If you have trouble making that happen, sometimes you have to move the physical trip dog a little and try again. Also because of the incremental encoder, the jumper on your drive should be on S1, not S2. (likely already is) Also your encoder cable should go to the CNC first, then from the CNC to the JV1B connector on the servo drive.
Usually I'd say stick to the MTB manuals, but here it wouldn't hurt to get all the manuals for the Fanuc OMC control, the Alpha series servo motors and amps, both connection and function. Parameter book and the lot. There is a bunch of information and parameters beyond the motor ones that need to be set if I remember correctly. Also if you're having minor stability problems, there are settings that aren't part of the normal ones that you can adjust to get rid of odd problems.
During my install, I spent hours pouring over the books and getting everything to go, but in the end I called in a local tech to go thru everything and finish the setup. Sometimes it just pays to pay and get it over with.
One last thing, and maybe you already know this, but to turn on and off the 4th, all you have to do is change parameter 19.1 to 0 to enable and 1 to disable. Can leave everything else as is.
