603,975 active members*
3,534 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Fiber Laser Cutting Topics > Cutting on uneven work surfaces. Work Surfaces with varying heights.
Results 1 to 1 of 1
    Aug 2024
    3
    Hello! I am exploring the possibility of cutting parts out of corrugated sheet metal. The issue I am facing is the laser head will drag the material around when it begins cutting due to the grooves and ridges of the corrugated metal. Scouring the user manuals has not shed any light on how to fix this issue. Any help would be appreciated!
    We are using an Amada Ensis 3015 with the AMNC 3i control.
    Nov 2013
    5414
    Re: Cutting on uneven work surfaces. Work Surfaces with varying heights.
    take a look at Autoleveler, it is a freeware or at least cheapware program that probes the surface and records the Z height. Then using the Z height it recasts the Gcode with alteration of the Z axis
    to follow the wave/bow/warp/corrugation of the material. It was designed for use on printed circuit boards but works in other situations as well.
    https://www.cncsoftwaretools.com/for...topic.php?t=60
    Craig
    Jul 2018
    6841
    Hi Fraz- sounds like you need an auto height control such as a plasma cutter uses. But I think it monitors the arc voltage to achieve this. Maybe an ultrasonic or inductive sensor set to measure ht will work. Peter
