Hi all,
I have a project that meet some problems. I have tried to make adjustments all I can, but still have some problems that I don’t understand. I am using an arduino uno to control nine relay modules (4 double and one single). I power everything with a power supply (12v 30A). The relays are powered from this through a voltage regulator (5 volt) and the arduino with a jack from the power supply.
When I power it up it is almost like one of the relays are floating or something, it flickers on and off when it should be on. When it’s off it stays off, so it is when it receives signal from the arduino.
Added:
Tools and code programming from Arduino Relay Module Use Step by Step.
Source: https://www.kukelec.com/how-to-use-r...duino-uno.html
Anyone has ideas?
