603,347 active members*
2,877 visitors online*
IndustryArena Forum > CAM Software > Alphacam > AlphaCam 2012 + Xilog Plus - Output NC no .pgm file type option
Results 1 to 7 of 7
    Hey guys,
    Desperately could use some help. In AlphaCam when I click 'Output NC' I don't have the option to select .PGM files from the file types. I have Xilog set as the post processor, I checked the 'Alternative File Extensions' add on, and even have another computer with the same config and settings (as far as I can tell) working fine. Both Windows 10 machines if that matters. Is there something I'm missing, if I can provide more info to help solve please let me know.
    Re: AlphaCam 2012 + Xilog Plus - Output NC no .pgm file type option
    Fixed it.
    May 2022
    14
    Merhaba. SCM Pratix S makinam?z var. PGM dosyas?n? nas?l alabiliriz. a?amalar? anlatabilir misiniz?
    Dec 2011
    9
    how did you fix it
    Nov 2011
    478
    It sounds like your AlphaCam configuration isn't recognizing the .PGM file extension for some reason, even though you have Xilog set as your post processor.
    1. Verify Post Processor Configuration
    Double-check that the post processor configuration on the machine where it's not working matches the one where it works.
    Go to Machine > Setup and ensure the Xilog post processor is correctly selected.
    2. Check File Extensions Settings
    Open AlphaCam, go to Machine > Advanced Settings or a similar section depending on your version.
    Ensure .PGM is listed under Alternative File Extensions. If not, manually add it.
    3. Compare Settings with the Working Computer
    Export the working machine's configuration settings:
    Go to the working computer.
    Export the post processor and machine configuration.
    Import these settings on the problematic computer:
    On the problematic machine, replace the existing configuration with the imported file.
    4. Permissions Check
    Ensure that the problematic machine has proper read/write permissions for AlphaCam directories and configuration files.
    Run AlphaCam as an administrator and check if the .PGM option appears.
    5. Reinstall/Repair AlphaCam
    If none of the above steps work, there might be a missing or corrupt file in the AlphaCam installation on the problematic computer.
    Try running a repair installation or reinstalling AlphaCam on the non-working machine.
    6. Registry or Environmental Differences
    Use a tool like Sysinternals Process Monitor to check if there are differences in how AlphaCam accesses files or the registry during output.
    Ensure that all dependencies and drivers for AlphaCam are consistent across both systems.
    7. Windows-Specific Differences
    Check that both machines have the same Windows language, regional settings, and version.
    Sometimes, issues with file handling can be tied to these differences.
    E-mail: [email protected] Web: www.elephant-cnc.com
    --------------Jinan Blue Elephant CNC Machinery Co., Ltd-------------
    Mar 2022
    85
    Hi, this is not enough I probably help you. Can you write me a message for the next information?
    Jan 2025
    Quote Originally Posted by elephantcnc View Post
    There is no option to select XILOG as post processor in alphacam. Can you send screenshot please where is it.
  1. Replies: 0
    Last Post: 04-14-2019, 08:07 PM
  2. Convert my pgm drawings to dxf without xilog
    By Chris2104 in forum CNC Machining Centers
    Last Post: 04-07-2019, 11:00 PM
  3. Xilog: How to convert PRG to PGM
    By blur in forum CNC Machining Centers
    Last Post: 02-13-2017, 03:58 PM
  4. PGM to TLF Xilog to Masterwork
    By harjedalskok in forum Uncategorised CAM Discussion
    Last Post: 10-01-2013, 10:39 AM
