603,882 active members*
3,949 visitors online*
Results 1 to 8 of 8
    Need help with G75 code on Fanuc 10
    Hello!
    I have a problem with the code G75 on the machine Takisawa TC-3 with the Fanuc 10 system.
    The program is already used on the machine Takisawa TC-3 with system
    Fanuc 0 and worked without any problems.
    When I switched to another machine with the Fanuc 10 system , G75 does not work.
    This is part of the program with the G75 where the machine stopped without an alarm, just a stop.
    M1
    G50X162.36Z247.98S1500
    G0G99G96S110T0707M16
    X85.Z2.M3
    Z-55.8M8
    G75R100
    G75X70.P300F0.07
    G0Z-52.2
    G75R200
    G75X70.Z-17.65P500Q3612R39F0.11
    G0Z-17.65
    G1X70.5F0.3
    G75R100
    G75X55.5P300F0.07
    G0Z-21.35
    G75X55.5Z-52.2P500Q3612R39F0.11
    G0X83.
    Z-55.8
    G1X70.5F0.3
    G75R150
    G75X54.5P400F0.12
    G0X100.
    Z10.
    X162.36Z247.98T0000
    M1
    Is it something that I need to change in the program or the problem may be in the parameters?
    Thanks in advance for your responses!
    Sep 2010
    1230
    Quote Originally Posted by bobancurug View Post
    Hello!
    M1
    X85.Z2.M3
    Z-55.8M8
    G75R100
    G75X70.P300F0.07
    G0Z-52.2
    G75R200
    G0Z-17.65
    G1X70.5F0.3
    G75R100
    G75X55.5P300F0.07
    G0Z-21.35
    G0X83.
    Z-55.8
    G1X70.5F0.3
    G75R150
    G75X54.5P400F0.12
    G0X100.
    Z10.
    X162.36Z247.98T0000
    M1
    The format for the O series control uses two lines for the G75 cycle, whereas the 10 series control only uses one block.
    The R value in the first line of the O series format sets the Return amount between pecks and is a modal value. This value can also be set in parameter #722 in the O series and remains until changed by specifying another value with G75 R in the program. Accordingly, if you wanted the two machines to have a similar one line format, and you're happy to have a constant retract amount across all G75 applications used with the O series machine, the value can be set in the parameter and the first G75 line in the cycle omitted. However, the series O and 10 control use a different syntax in the main G75 block. Therfore, the programs aren't transportable between the two controls.
    The syntax for the G75 cycle for the 10 series machine is as follows:
    G75 X(U).... Z(W).... I.... K.... F.... D.... Where:
    X = Finish point in X
    Z = Finish point in Z
    U = Incremental value of X
    W = Incremental value of Z
    I = Step across movement in Z direction
    K = Depth of cut in the X direction
    F = Feed rate
    D = Relief amount for the tool at the end of the cut in Z.
    In the above format, Z,I and D are used if the cycle is to be used to machine a groove wider than the width of the grooving tool, or for a series of holes where the pitch of the holes will be described by I and the last hole coordinate by Z.
    1. When used for any drilling operation, parameter D is omitted.
    2. When used to drill a single hole Z,I and D are omitted. When omitted, the D parameter is assumes to have a value of zero, and Z and I are ignored in software.
    The Return amount set by R in the first G75 line of the O series control format, is set in parameter #6217 of the 10 series control. Unlike the O series, this is the only way the Return amount can be set on a 10 series machine.
    Regards,
    Bill
    Thanks Bill for this excellent explanation, tomorrow I'll try to rewrite the program, and also to try that with changing parameters
    Thanks again,
    Boban
    Feb 2006
    1792
    R in the first block should be in mm/inch, not in micron/thou.
    Oct 2011
    Can anyone explain what the Q & P values in this line actually mean?
    The G75 lines that Im looking at have the format:
    G75 X Z P Q F
    Cheers for your help!
    Sep 2010
    1230
    Quote Originally Posted by ESP666 View Post
    G75 X Z P Q F
    G75 canned cycle can be used for grooving or drilling in the X axis. The P and Q have the following meanings:
    1, P = the peck amount before retracting to chip break.
    2. Q = the side steps along the Z axis in a grooving operation, or it could be used as the pitch between holes in the Z axis if being used in a drilling operation. Note: If used in a drilling operation, R must be assigned zero.
    Quote Originally Posted by sinha_nsit
    sinha The R in the first block is saved in parameter #722 and is model, ie. the value stays the same until a different value is specified in a G75 block, or changed via MDI. Its stored in units of 0.001mm or 0.0001inches, depending on the configuration of the machine; the range is 0 to 99999999. Unless the control is configured to use Calculator style decimal input (selectable via parameter) the R value in the first G75 block can in fact be specified either with or without a period. If no period is used, the value is considered in terms of the number of least input units.
    Whilst there are some arguments that must be specified without a period, all dimensional addresses such as X(U), Z(W), I, J, K, R etc can be specified without a period provided they are padded with the correct number of "0" so that a true representation of the intended value is preserved
    Regards,
    Bill
    Feb 2006
    1792
    With calculator-type setting, R should be in mm/inch.
    Is it correct now?
    Oct 2011
    Thanks Bill!
  1. Replies: 4
    Last Post: 03-29-2011, 02:39 PM
  2. fanuc program code vs. Haas code
    By sixty8frbrd in forum Fanuc
    Last Post: 03-11-2011, 04:05 AM
  3. Converting Fanuc G code to Seimens 840D G code
    By Jasbinder in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 02-20-2011, 05:02 PM
  4. fanuc OT 401 code
    By dc123 in forum Fanuc
    Last Post: 12-31-2010, 07:48 AM
  5. Fanuc M-Code
    By bz1801 in forum Fanuc
    Last Post: 09-28-2005, 05:42 PM
