587,307 active members*
3,754 visitors online*
Results 1 to 3 of 3
    Aug 2007
    57
    encoder question
    hello cnc zone
    i have a ac servo with a encoder . i have the spec sheets for the encoder . but im un sure how to read the symbols . i have seen a thread around here before with the anwser but i cant find it .
    here goes
    the spec sheet has the letter of the channel.example A then a letter A with a line over top.
    the drive board im using lists a- a+ in/outputs for the encoder.
    i hope this makes sense . how do i hook this encoder up ?
    thanks
    mike
    Dec 2003
    24223
    This is a couple of methods used to indicate the relative logic levels for the encoder signals.
    A B & either Z or I is used for the different channels with I & Z being the once/rev marker pulse.
    A+ = A
    A- = /A (the inversion of A)
    B+ = B
    B- = /B
    and so on.
    Al.
    Albert E.
    Aug 2007
    57
    thanks al i seen you posted the same info before i just wasnt able to find it .
    have a good one !
    cheers
    mike
  1. absolute encoder question
    By JasonCampbell in forum Servo Motors / Drives
    Last Post: 09-05-2007, 03:59 AM
  2. encoder question
    By dertsap in forum CNC Machine Related Electronics
    Last Post: 10-19-2006, 01:19 PM
  3. encoder question
    By homebrewCNC in forum Mach Software (ArtSoft software)
    Last Post: 03-31-2006, 04:36 AM
  4. Encoder Cable Question(s)
    By murphy625 in forum CNC Machine Related Electronics
    Last Post: 03-06-2005, 09:00 AM
  5. Linear Encoder Question
    By Verboten in forum Linear and Rotary Motion
    Last Post: 08-30-2003, 09:04 PM
