What settings in the machine dynamics should I have for a mazak vmc510c?
You will need to run a test on your machine to see what it can do. Each machine will be different based on weight of the mass being moved(fixtures ect) and what options the machine has(high speed or not).
Go into your General Machine Parameters page in your machine definition and then go to the Machine Dynamics tab. On that page there is a button for Cornering Acceleration. Click on that button and it will open a little window with options. Press the ? for the Help. In there is a link for info on how to run a test that will determine what values you need to use.
HTH - Hope This Helps
AC
AC
Has anyone seen my pillow?
