603,403 active members*
3,967 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Solids vs. surfaces
Results 1 to 5 of 5
    Jul 2005
    42
    Solids vs. surfaces
    I read somewhere that solids was preferred over surfaces for toolpathing 3d contours. Why is that? What are the benefits?
    Mar 2005
    461
    I think the advantage is that a solid can be selected as "drive" in a single click where as to select all your surfaces would require a selection window or one of many other options...
    There are limitations though...
    For example, select a few faces for "drive" and a few faces for "check" on a single solid... MC seems to be confused by this activity...
    I prefer to use solids generally but as soon as I run into a snag I just create surfaces from the solid and use those instead.
    May 2007
    71
    thanks
    Jun 2005
    305
    Another advantage to using a solid is when evaluating the toolpath, Mcam can tell when a solid 'face' is under another one thereby ignoring it.
    It makes for quicker toolpath generation for parts or molds that have thousands of 'faces' or more.
    You won't notice the speed increase on very simple parts of a few hundred faces or less.
    I worked on molds that had up to 100,000 faces and could take hours to generate one path.
    So I have the habit of using ONLY the surfaces I need to generate the part.
    Time is money and all that BS.
    ObrienDave. MasterCam since V6. Gcode since 1983.
    The nose you punch today may belong to the butt you have to kiss tomorrow.
    Apr 2003
    3578
    Some other thoughts are that Surface models are not water tight models in lots of cases you can get an Iges model that has gaps in between surfaces.
    Solids are water tight models no duplicates no gaps for the tool to jump in to.
    Also have you tried getting wire frame from a surface model ther are more splines then needed there are lots of dups in he edges. you do not get this you get clean wire ready to cut from.
    Also review link.http://www.mastercam-cadcam.com/vide...dadvantage.wmv
    Opps I miss spelled SOLIDS.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
  1. Solids / Surfaces question
    By DonW in forum BobCad-Cam
    Last Post: 12-27-2007, 01:08 AM
  2. Surfaces
    By JPWMachining in forum Mastercam
    Last Post: 11-16-2006, 04:43 PM
  3. Trying to teach myself surfaces and solids.
    By Nbdy in forum Mastercam
    Last Post: 03-13-2006, 06:41 AM
  4. V18 tutorials and book V19 solids/surfaces
    By fastolds in forum BobCad-Cam
    Last Post: 12-26-2005, 05:06 PM
  5. Converting solids, and surfaces
    By MILLMANM in forum Mastercam
    Last Post: 01-05-2005, 06:31 PM
