603,424 active members*
3,622 visitors online*
Results 1 to 2 of 2
    Oct 2007
    76
    Question L6203 in Parallel ???
    Hello Everyone,
    I'm trying to design a High Ampere (4-8A) Bipolar stepper Driver and I am looking at various possibilities now.
    I came across the L6203 4A Full Bridge from ST. This is the basic L297/L6203 Bipolar Stepper driver setup.
    L297 + 2 x L6203 Full Bridge ===> 4A Max per Phase
    I checked the L6203 Datasheet and it says 4A MAX in FULL Bridge Mode. I was just wondering if its possible to use the L6203 in a half bridge mode? So my setup would look like:
    L297 + 2 x L6203 Half Bridge + 2 x L6203 Half Bridge ===> 8A Max per Phase
    Is such a setup possible? Any idea/Suggestion/Opinion is highly appreciated.
    Please Advice!
    Thank You,
    Joe!
    Jul 2008
    411
    I dont see why not, parallel all inputs and outputs in a 6203. MOSFETS you can do this with as their resistance increases with temperature so they are naturally self-balancing. I'd probably limit it to 6A in reality rather than push for the full 8 as I've read elsewhere here that heatsinking at the limit is an issue with the 6203.
    Would be easy to mock it up to test dissipation and current sharing...
  1. Problems with stepper driver (L297 and L6203)
    By MagooT in forum Open Source Controller Boards
    Last Post: 09-07-2012, 12:35 PM
  2. CONTROLADORA BIPOLAR CON EL L6203 -l297
    By lupi200 in forum Spanish
    Last Post: 11-21-2011, 03:39 AM
  3. L6203 out performs L298
    By dalescnc in forum CNC Machine Related Electronics
    Last Post: 03-02-2011, 08:25 AM
  4. help on L6203
    By ahmed in forum Stepper Motors / Drives
    Last Post: 11-11-2008, 03:45 PM
  5. L6203+L6506+DAC+MCU=Where?
    By Cooper in forum Open Source Controller Boards
    Last Post: 01-24-2007, 08:02 PM
