I visited Frans from Toolmach Aust today to have a look at how he mounted his QCTP on his C6 lathe.
As the cross slide that comes with the lathe is redundant for CNC I am removing it and machining up a block of steel to replace it. The QCTP will be mounted on to of the block.
Frans was kind enough to donate a block of steel for me to use and I squared it off and machined the bottom on the X4+ so it will mate with the cross slide base (which I am re-using).
Photos are a bit blurry as they are from my phone.
