603,964 active members*
3,678 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Disable the internet palette?
Results 1 to 2 of 2
    Mar 2010
    Is there a way to totally disable the internet palette in TurboCAD 17?
    In posting http://www.cnczone.com/forums/turboc...t_loading.html I have been having a load problem that seems to be linked to the Internet palette constantly “Seeking” or trying to load something that never loads, I got in once and set the home page to “Blank” but it is still trying to load something.
    I don’t really care to use the browser inside TurboCAD, so if I could get into the registry or some configuration file and disable it that would be great.
    Anyone have any ideas of where to go to disable this?
    Dec 2006
    43
    Disabling the Internet
    In your program folder, there is an INTERNET folder and inside there a file with the HTML extension. Try renaming the file (so you just don't delete it but rather can rename it correctly if you want to later)...i.e., the files' name is Internet.html, rename it to Internetxxx.html
    See if this will work. Bob.
    Actually, the file's name palette.html, rename it paletteXXX.html.
  1. CNC ROUTER 346 PALETTE BIESSE
    By badsousa in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-22-2011, 10:55 AM
  2. CNC ROUTER 346 PALETTE BIESSE
    By badsousa in forum Post Processors for MC
    Last Post: 12-09-2010, 09:06 PM
  3. SW 2010 dimension palette
    By sambudy in forum Solidworks
    Last Post: 02-26-2010, 11:45 PM
  4. How do you disable SMI?
    By CROSSHATCH in forum LinuxCNC (formerly EMC2)
    Last Post: 03-04-2009, 10:22 PM
  5. Anyone ever had palette misalignment problems?
    By Driftwood in forum Uncategorised MetalWorking Machines
    Last Post: 12-12-2007, 03:09 AM
