603,968 active members*
1,482 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Cutting a cast iron slab?
Page 1 of 2 12
Results 1 to 20 of 25
    Mar 2005
    1673
    Hi all,
    Any one got any idea how I could cut through a 2 1/2” x 20” x 30” slab of cast iron with out industrial machinery?
    Please don't say an hack saw and a lot of time
    John
    Jul 2005
    101
    abrasive disk in circular saw... clamp on guide and go.
    Mar 2005
    1673
    Quote Originally Posted by jpgdesigns View Post
    Hi
    Would that be safe and how long would 20” take to cut via this method hrs?
    John
    Oct 2005
    1238
    Arrow Cutting Cast Iron
    Quote Originally Posted by Oldmanandhistoy View Post
    Any idea how I could cut through a 2 1/2” x 20” x 30” slab of cast iron?
    Air-carbon arc (Arcair) will cut through the slab of cast iron.
    Some information is HERE.
    Research the process to see if it meets your requirements. It's much faster than a hacksaw!
    Jul 2005
    12177
    Cutting through the entire 2" thickness is going to be slow and probably go through a lot of abrasive blades.
    How good do you want the edges and where is the cut? If the cut is near the middle and you can accept rough edges you could cut a shallow groove, something like 1/4" deep. Now with a bit of luck if you let the slab fall with the groove down so the end lands on a thin piece of wood it will break.
    Or you prop one end on a piece of wood and drive your car onto it.
    Mar 2005
    1673
    Thanks Weldtutor
    Hi Geof,
    Breaking is not an option and the edges will be milled flat straight.
    Does anyone think a saw with one of the new metal cutting blades might do the job?
    I would have about 5 cuts to make
    I think this may be madness (chair)
    John
    Jul 2005
    12177
    .....I think this may be madness (chair)
    John
    Yes I agree but I have done many mad things in the past so I will continue to encourage you.
    Cast iron has to be machined much slower than steel, but in some ways it is easier to machine, or at least some types are. Do you know what this slab is? If it is ductile cast iron or malleable cast iron trying to cut it is only slightly mad. If it is grey cast iron trying to cut it is a bit madder. If it is white cast iron I am coming over to lock you up.
    My guess is that it is likely to be ductile or malleable so I will continue.
    A triple chip metal cutting blade would die almost instantly if you tried cutting at normal table saw speeds, however if you could slow things down considerably and if you could keep a nice steady feed through the blade your stand a good chance.
    Can you rig up some method to slow down your saw? A couple of jackshafts with a 10 : 1 reduction ratio through a few pulleys to drop the speed down to 200 or 300 rpm or maybe lower.
    Then clamp a couple of strips of wood on the table on both sides of the slab so it will not twist on the blade and take a cautious cut only about 1/2" deep and see how things go. If things go smoothly get more ambitious.
    Mar 2005
    1673
    All I know is its from a very old marking out table.
    I'm thinking one of those hand held saws with http://www.toolstoday.com/c-326-stee...aw-blades.aspx something like this?
    John
    Feb 2006
    794
    If you have to do it in your home shop then possibly you could set up some guides and use a router and 1/4" end mill, but it will take many passes as you can't take a big bite ! but it would probably be easier than using Abrasive wheel as the wheel will likely want to bind if it is not totally rigid. I used a router and carbide end mill to run a cleanup on both sides of my collumn and some clearances within my box and it worked pretty good. Can't take a lot of depth per pass but you can rip each pass real quick so it may not take too long at all. Use a good carbide cutter to handle the higher speed of router and wear a face shield over glasses, and use mask too. The dust will go everywhere.
    Don
    IH v-3 early model owner
    4826
    This sounds like a job for someone with a large bandsaw. Even a small band type sawmill would do, provided they could really slow the band speed down, which might require some additional rigging to accomplish. You'd have to buy them a bimetal band though.
    First you get good, then you get fast. Then grouchiness sets in.
    May 2007
    781
    Great great grand pop would have used a hammer and chisel. Cut a grove on each side and one good smack with a big hammer and you have two parts, works even better in the winter when things are well below zero.
    Then throw them on the shaper/planner and square up the edges. If the shaper/planner was big enough he could use that to cut the grooves.
    Likely would have been a lot faster then you think, but then gramps had a lot more arm muscle then your average machinist today.
    Jul 2005
    12177
    John
    If it is a marking out table it is most likely ductile iron so that is okay.
    The problem with using a hand saw with one of those blades is the speed. Even with carbide tips you have to go slow on cast iron. Part of the problem is that if the cast iron gets red hot, which it can do in a small region right at the cut when the blade is running too fast, it chills quickly due to the large bulk of material behind. The procedure for making white cast iron is to chill it from a high temperature so guess what you finish up trying to cut when you go too fast. Actually things can go downhill very fast and you may end up with fragments of blade welded into the cut and other fragments located in other areas; sometimes the other areas hurt.
    Seriously; I think trying to cut it with a hand saw using any blade is approaching white coated men madness.
    Cruiser's router idea is quite sane provided you can get the speed down into the less than 1000 rpm region.
    Before I had looked at your link I wondered if it was a Sawz-All. This tyoe of thing:
    [ame="http://www.amazon.com/Milwaukee-6537-22-Super-Sawzall-Quik-Lok/dp/B00002247I"]Amazon.com: Milwaukee 6537-22 Super Sawzall with Quik-Lok Blade Clamp: Home Improvement[/ame]
    With a bimetal blade you may be able to do it provided you control the blade speed. The Milwaukee unit pictured has a speed preset so you can avoid going to fast and is quite a good unit. (I am biased, I have one) It is not cheap.
    Mar 2005
    1673
    Quote Originally Posted by Geof View Post
    Great minds?
    Just looking at these but wondering if they can manage the 2 1/2” depth of cut without the blade bending?
    John
    May 2007
    781
    If you got an old gear box laying around you could put together a simple dragsaw using a big ridge hacksaw blade.
    [ame="http://www.youtube.com/watch?v=eU2AnP2Ji4s"]YouTube - Drag Saw Model-1/3rd scale[/ame]
    If its Geof's white cast here is one for cutting rocks.
    http://www.scienceray.com/Technology...Dragsaw.386075
    Jul 2005
    12177
    Great minds?
    John
    Probably. You need good strong wrists and both you and the work have to be in a stable position. I have gone through large steel tubing and I beams with mine.
    One problem with a wide cut is getting enough tooth pressure and you have to rock the blade so only a few teeth are engaged. If you don't keep up the pressure you can glaze cast iron and create a hardened surface.
    Mar 2007
    56
    Many years ago I cut some cylinder blocks for a 6 inch scale steam truckfrom a similar sized piece of cast iron. I chain drilled using a hand held electric drill and a half inch drill. After drilling I put a small pivot under the row of holes and hit one side with a 28 pound hammer. The raggedy edge was cleaned up with a flexi grinder with a 6 inch wheel and then machined in a mill. It took 2 or 3 lunch breaks at work to drill the row of holes but I cannot now remember the number of drills I drew out of the toolstores.
    John.
    Jun 2007
    41
    Use an abrasive blade intended for aluminum. I was cutting cast iron one day with my abrasive chop saw, and the regular blade all but refused to cut through it. I switched to the aluminum cutting blade and it went through like butter. I think it has something to do with the clogging tendancies.
    Jan 2009
    237
    Those new steel cutting circular saw blades are sure trick.
    I have used them to cut a lot of stuff. I beams, grating, angle stock, plate, thick and thin. No CI though, but what can be different? CI should be easier.
    Millwaukee offers a special saw, but it just a skill saw with some extra chip deflectors.
    $60 will get you a blade, You must have a saw already???
    CalG
    I
    Jun 2007
    41
    thats what you would think, but my dry cut saw said specifically not to use it on cast iron or aluminum
    Jan 2009
    237
    dang carbon!
Page 1 of 2 12
  1. Cast Iron
    By Zumba in forum Casting Metals
    Last Post: 01-22-2009, 10:50 PM
  2. cast iron machining
    By drwc in forum MetalWork Discussion
    Last Post: 01-16-2007, 05:20 AM
  3. bending cast iron
    By Goofour in forum Bending, Forging, Extrusion...
    Last Post: 10-21-2006, 06:38 PM
  4. Where to buy cast iron plates?
    By Zumba in forum MetalWork Discussion
    Last Post: 04-13-2006, 02:04 PM
  5. Rust on Cast Iron
    By ChrisJ in forum MetalWork Discussion
    Last Post: 05-18-2005, 07:06 AM
