603,932 active members*
2,782 visitors online*
Results 1 to 5 of 5
    Nov 2004
    284
    Which Ball Screws to use?
    Hi Guys
    I need some help Guys? I am trying to decide which size of Ball Screw I should be installing in the Mill that I am converting to CNC? You can see a picture of the Mill below. The Mill will be used mainly to machine Aluminum with a little Steel. I do plan to use the Mill allot. So it’s either 5/8” or 3/4” Screws? I was originally planning to use 5/8” Screws but have been told by more than one person that I should be installing the 3/4” ones. What do you think about this?
    Here is a list of the other components I will be using:
    (Servo Motors)
    C23-L55 Poly-Scientific.
    Peak Torque = 430 oz.in.
    Continuous Stall Torque = 50 oz.in.
    Rated Torque = 40.5 os.in.
    Rated Speed = 1700 rpms.
    (Ball Screw Nuts)
    Pre-loaded Ball Nuts with Wipers. (Uses two single circuit nuts per screw)
    (Ball Screws)
    Linear Error per foot = 0.001 to 0.003
    Screw mounted on double Angular Contact Bearings
    (Drives)
    Belt drive with a 2:1 ratio between Servo Motor and Ball Screw.
    (Mill Sliding Surfaces)
    Original Cast Iron Ways.
    Thanks for the help.
    Willy
    2139
    I am using 5/8", as have many others. 3/4" would of course be better but more money.
    Eric
    I wish it wouldn't crash.
    Nov 2004
    284
    Hi Balsaman
    Approximately how many hours do you think you would have on your 5/8" Ball Screws? Have you noticed any wear (increased backlash) on the Screws since they were installed? Approximately how often do you lubricate your Screws?
    I guess what I am trying to figure out here, is the benefits for going with a 3/4" Screw instead of using the 5/8” ones? As far as the maximum load difference between these two Screws, it’s only 125 lbs. 5/8” Screws are rated at 825 lbs. and the 3/4” ones are 950 lbs. I guess for the same applied load, the 3/4” Screw will more than likely last longer because it has more area to carry the load. I can’t see machining pressure being anywhere close to the 825 lbs. rating of a 5/8” Screw, especially when working with Aluminum. Maybe I am missing something here, but I just can’t see that much of a benefit by going with the larger Screws? Price difference between the two is approximately $250.00 which is a little more than half the cost of the 5/8” Screws. Anyway’s, I need to make up my mined soon and would be interested in hearing any and all comments with either setup. Thanks for all your help.
    Willy
    2139
    I am just doing the conversion now: http://www.cnczone.com/forums/showth...80&page=1&pp=5
    Eric
    Apr 2004
    439
  1. Revolutionary Linear Drive System
    By allanconway2 in forum Polls
    Last Post: 08-13-2020, 12:19 PM
  2. Ball Screws & Nut Advice
    By coolman in forum Uncategorised MetalWorking Machines
    Last Post: 12-24-2004, 03:29 PM
  3. Correct Pre-loaded on Ball Screws?
    By Willyb in forum Uncategorised MetalWorking Machines
    Last Post: 12-09-2004, 04:09 PM
  4. Ball screws singles/doubles/preloaded???
    By replicapro in forum Uncategorised MetalWorking Machines
    Last Post: 06-18-2004, 05:48 AM
  5. Z-Axis and Ball Screws
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 01-10-2004, 09:10 PM
