Originally Posted by
5artist5
How would I go about cutting a part this shape?
I have bobcad V21 and it seems to have three cutting path strategies.
1) A linear back and forth pattern.
2) a Radial pattern that moves from the center out to the edge or vice versa.
and
3) A spiral pattern
So these are my questions.
1) Is there some way to do this easily with just the G code? I have done some basic G coding. The straight line parts of it I get how to do, but can I say, "do a straight line from this point to that point then make 90 degrees of a .250 radius and then go to this other point?
2) Is there a way to have BobCad actually follow a path like that?
or 3) Can I just use a small cutter and use say the radial pattern and have it cut that notch that way?
It is a gasket channel, so it should be pretty smooth...
