603,379 active members*
4,045 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > X2 Mods - additions and improvements to an X2?
Results 1 to 18 of 18
    May 2009
    11
    Hi Guys
    What are the first and then I suppose more advanced mods that can be done to an X2? When I got my mini-lathe I found a few sites with some good mods and also plans for building tooling accessories for the lathe but I havn`t found anything similar for the mini-mill.
    I only know of the belt drive conversion which has been done, and altering the gibs to reduce backlash and addition of DRO bars -which I have done.
    I believe you can add a spring mechanism and permanent fixtures for the spindle locking pin but I haven`t seen any plans or pictures for this mod - it is certainly something I would like to try.
    I suppose you could say I am looking for things to do for the sake of it, but it is a hobby and I`m enjoying it! :rainfro:
    Mnbylcr2
    Jul 2008
    922
    CNC it
    Dec 2007
    362
    Increase Y travel - this one doesn't look too difficult, provided you have a spare mill to do the work on
    Column brace
    There's a number of spindle lock mods including this one from Hoss.
    But as Teyber12 said, CNC it. You know you want to...
    Regards
    Geoff
    May 2007
    14
    Coolant (definitely a must have/do), power draw bar (not absolutely necessary but…), both can be either purchased or 100% DIY projects.
    CNC!!! :violin:
    Mar 2006
    489
    X2's are made to CNC. I'm with the others, cnc it ASAP. Or buy the extra one I have....
    May 2009
    141
    You can upgrade the power supply and get more torque and speed out of the motor. Pretty easy to do and can be done cheap if you watch for a good deal on E-bay for the power supply board.
    Dale P.
    Mar 2006
    489
    what are the specs?
    Jun 2007
    84
    stiffen up the column
    If you want a simple mod that can make your setup alot more solid, try stiffening up the column/base. Use epoxy, epoxy-modified cement or just plain 'ol cement and fill the lower half of the column- gets you a lot more stability. For extra added measure, chuck the thick washer on the back of the column and replace it with a steel or aluminum plate- its shape makes it act like a spring. If you wanna go full-on ridiculous (like I did) you can rig up either an angle plate, a brace system or something similar to put the coup-de-grace to deflection in the column.
    A belt drive (look at Sterling Steele or some of the others mentioned through the forums for the X2) is almost mandatory if you want to not go out of your mind while machining with it. If a belt drive isn't in you plans, if you don't want the temptation of taking a hammer to it WHEN (not if) you break a drive gear, I'd suggest replacing the plastic gears with metal ones- littlemachineshop sells 'em.
    An air spring conversion kit is a good investment- it gets you a bit more Z travel. If you wanna upgrade even more, you could use a counterweight system.
    DRO's are a good idea if you are going to keep it a manual machine.
    If you want to do any 4th axis work, a rotary table or something similar is needed, and can be cheap if you hit ebay alot.
    ...and of course, CNCing it is always a good idea. If you like to mod your machine, you're likely to go that route in any event eventually...
    -Farasien
    May 2009
    11
    Thanks for your replies so far - please keep them coming.
    I already have the air spring conversion so I think my next one will be the belt drive kit - unfortunately doesn`t look to be available from a UK supplier - can anyone clarify this?
    I have still not seen anyone mention or send a link to the spring loaded spindle locking pin?
    I may consider the column support - I could do with some plans though! - I`m not an engineer by profession and therefore struggle replicating pictures without detail or ideally plans.
    Please do link up - I am familiar with "search" (nuts) but you know what it`s like, most of you guys have been on here for longer than me and know what posts are best for the info.
    ....keep it coming. Chris
    Feb 2007
    4550
    Post
    Chris,
    I though you might like this.
    Jeff...
    Attached Files Attached Files
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Dec 2007
    362
    I got mine from LMS. Quick service, reasonable shipping rates.
    Check my last reply or go directly to Hoss and borrow his design.
    Go the yahoo group I linked to and ask the person who posted the photo. They're a helpful bunch over there too.
    Regards
    Geoff
    Dec 2007
    362
    Quote Originally Posted by jalessi View Post
    Chris,
    Jeff...
    Wish I;d seen this one before I bought my belt drive kit!
    Regards
    Geoff
    Dec 2007
    362
    My own X2 plans
    For what it's worth, here are the mods/improvements I plan to make to my X2:
    1. Belt drive - already done using LMS kit. Real reduction in noise which I'm sure my neighbours appreciate.
    2. DRO and scales - I've got a Shumatech DRO kit to build and 3 scales from Shars. Still to design and make some suitable mounts. Lots of ideas both here and in the Yahoo (Shumatech and GrizzlyHFMiniMill) groups.
    3. Y travel extension - Previously mentioned the link to this one. If I do this then I'll certainly do 4.
    4. Column support - a 15mm - 20mm steel plate to mount the mill on and a large angle bracket should do the trick. Not sure about the epoxy filling though.
    CNC is on the list but I want to get some manual milling experience first - while I save money to buy the CNC bits.
    Regards
    Geoff
    Jun 2007
    84
    I wouldn't bother buying the CNC parts... If you have a decent set of accurate calipers, your mill has a working DRO (or you really know how to do accurate machining without it) and know a few fundamentals, you cam make them for the cost of a few plates of aluminum and a weekend's worth of time. That is, if you aren't considering upgrading to ballscrews. In any case, go check out Hoss's site (www.hossmachine.info)- he has most of his plans for free on there and sells stock kits and plans for a whole bunch of other interesting mods.
    The nice thing about learning how to manufacture stuff is you'll find, more and more, you don't have to buy much of anything anymore outside of raw materials and the occasional tool.
    -Farasien
    Dec 2007
    362
    When the time comes to CNC, I hope to make the mounts my self. The bits I have to buy are the motors, controllers, ballscrews etc.
    Regards
    Geoff
    Chris,
    Jeff...
    BeltDrive1.pdf‎
    I built my belt drive from that design from J. Rollett posted on the GrizHFminimill Yahoo Group.
    I made a few changes to make fabrication easier.
    Some of the pdf dimensions are not correct such as the motor mount holes.
    I left out the provisions for mounting a Hall IC Sensor but would leave that in now to output RPM.
    JR did a great job, it's as nice as LMS's.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    May 2009
    141
    Here is the link for adding a new power supply to the 2X mill. Sorry I thought I added it to my last post. It's a pretty easy project to do and made a big difference to my machine.
    Dale P.
    http://www.harrisson.biz/controller/power.htm
    Apr 2005
    1778
    Quote Originally Posted by tumutbound View Post
    Column brace
    Here is a link to a post that I made on my Y axis extension and a drawing showing the measurements.
    Alan
  1. Joe's CNC Model 2006 (Mods & Additions)
    By joecnc2006 in forum Joes CNC Model 2006
    Last Post: 04-03-2013, 09:55 PM
  2. Owners manuals need improvements!
    By AMCjeepCJ in forum Milltronics
    Last Post: 11-22-2009, 05:34 AM
  3. Additions/Modifications to David Steele's Solsylva CNC
    By DougO in forum CNC Wood Router Project Log
    Last Post: 04-13-2008, 10:46 AM
  4. Taig Headstock Improvements??
    By scubasteve_911 in forum Taig Mills / Lathes
    Last Post: 08-22-2007, 06:10 PM
  5. More Improvements
    By rodneydeeeee in forum Dolphin CAD/CAM
    Last Post: 03-22-2007, 10:40 AM
