603,796 active members*
3,815 visitors online*
Results 1 to 9 of 9
    Mar 2004
    17
    Question A terminology question
    I'm planning a project requiring a rotating table.
    The problem is, I don't know the proper name for the bearing used on the rotation axis.
    I know that regular bearings (e.g. roller-blades) won't do because they are not designed to carry a load on the rotation axis.
    The closest common application (I can think of) for the bearing I'm looking for is for a roulette wheel.
    Feb 2004
    2337
    Could the term be "Thrust bearing" ?
    As used in a washing machine?
    Jun 2003
    451
    Tapered bearing. Like those used on the spindles of cars and trucks. If you go to a place that sells bearings and tell them what you want they should be able to advise and give prices.
    746
    angular contact bearing?
    If it's not nailed down, it's mine.
    If I can pry it loose, it's not nailed down.
    Mar 2004
    564
    Thrust Bearing is the correct term.
    They come in many diff. configurations, including tapered and angular styles.
    A spinning bearing has loads is a radial direction and axial direction. When designing, you need to consider the amount of force/load the bearing will have to handle in both directions. Because everyones application is so different, there is no black or white awnser, just varying shades of grey, so to speak. Heavy thrusts @ low speeds may be better suited for a tapered bearing, if the thrust is not severe, you may be able to stack angular contact bearings in the correct order, to achieve support, You may also be able to use a "Conrad" style radial bearing with deepgrooves. There is a trade off for each, speeds they can rotate at, the amount of "room" they take up in your assembly ect....
    hope this helps
    menomana
    Mar 2004
    17
    Quote Originally Posted by trubleshtr
    Thanks, now I know what to look for.
    My application will probably not strain the bearing too much.
    I'm looking at a weight of about 4-6 lbs, and very low speed of about 20 rpm.
    746
    How big of one do you need? I have a few NTN 16026 deep groove radial bearings floating around here.
    O.D.- 200 mm
    I.D.- 130mm
    THK- 22 mm
    Load- 17,900 lbs
    They were used in panoramic x-ray machines, head rotation assy's. Those x-ray machines at the dentists office that go around your head. At one time I was going to make a rotary table and then a large turntable for one of those garden railways, but never got around to it.
    Mar 2004
    17
    I was thinking about I.D. of 5/16", to fit my existing hardware.
    17,900 lbs is 3 orders of magnitude more than I need.
    I can probably manage with low end bearings.
    35494
    Sounds like you can use rollerblade bearings.
  1. Extremely basic machining question.
    By touser in forum MetalWork Discussion
    Last Post: 06-19-2005, 06:51 AM
  2. Question about power supplies
    By dowling177 in forum CNC Machine Related Electronics
    Last Post: 01-28-2005, 02:01 PM
  3. Hobbycnc controler question
    By chas in forum Hobbycnc (Products)
    Last Post: 09-09-2004, 11:00 PM
  4. Just a question about plunge milling.
    By Machine1 in forum Hard / High Speed Machining
    Last Post: 01-29-2004, 03:36 AM
  5. HF lathe question
    By rs1300 in forum Uncategorised MetalWorking Machines
    Last Post: 01-19-2004, 06:22 PM
