603,895 active members*
4,457 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > eliminate start and stop of spindle for short program?
Results 1 to 5 of 5
    May 2006
    98
    I have a short program I would like to run over and over without having the spindle stop, to eliminate the ramp up wait, and save on energy costs by not constantly starting and stopping (it's about a 10 second program). How do i do this? I imagine I can maunually edit the mach3 code to do it, but haven't been successful. I've tried eliminating the M commands but can't get it to do what i want. Thanks!
    Jul 2008
    14
    instead of a m30 at the end of the program use a m00 to stop and change part then a m99
    should loop the prog without stopping spindle
    35494
    Just take the M codes out of your progam, and start the spindle before you start running parts. Stop it when you're done.
    35494
    Just noticed, in General Config, try unchecking the option to "Turn Off Spindle On M30".
    May 2006
    98
    spindle non-stop solutions
    thanks for help. Solution 1 works pretty well, but necessitates 2 cycle start hits between cycles, and maunual changing of each program. #2 which I had tried and couldn't make work, I didn't try again. And Ger had the best advice of all, a simple easily reversed config change, which I had looked for and missed. Thanks, this forum is the best!(And I"m so happy that my machine now runs well enough I seldom need it!)
  1. vfd spindle start/stop problem
    By endgrainguy in forum CNC Machine Related Electronics
    Last Post: 12-14-2010, 05:49 AM
  2. G-Code to start and Stop Spindle/Router
    By planekrazie in forum G-Code Programing
    Last Post: 02-09-2009, 03:54 PM
  3. spindle start/stop through VFD
    Last Post: 01-09-2009, 04:47 PM
  4. Super X3 spindle start/stop from Mach3
    By jallitt in forum Benchtop Machines
    Last Post: 06-22-2008, 02:23 PM
  5. Stop/start a program
    By jimglass in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-10-2003, 02:59 PM
