603,968 active members*
2,170 visitors online*
IndustryArena Forum > CAM Software > Vectric > Arc Fitting Geometry = Reduced 2D Toolpath Sizes
Results 1 to 1 of 1
    Aug 2005
    597
    While talking with a VCarve Pro customer who was asking why
    his toolpaths were all point-to-point moves, I realised that
    we hadn't fully promoted or explained the usefulness and power
    of the new Arc Fitting tool available in version 5 Aspire 2.
    After explaining how the Arc fitting would improve his 2D
    profiling and pocketing toolpaths. The customer experimented
    with the Arc fitting and was amazed to find out that the toolpaths
    were significantly smaller around 1/4 of the original size of the
    bezier based toolpaths and his CNC machine is running much
    smoother.
    To get a feel for the results obtained by using the Arc fitting
    tool, I tested the option using the Velocette example show below.
    After Vectrorizing / Tracing the original jpg image of the logo,
    the resulting vectors were all bezier curves and lines.
    I then created a new layer and copied the original bezier vectors
    onto this layer. Using the Arc Fitting Tool, the beziers were
    converted to Arcs using a tolerance = 0.005" / 0.1mm.
    Calculating toolpaths using the two sets of vectors gave the
    following results,
    Pocket - Bezier Toolpath = 22,156 lines of CNC code
    Pocket - Arcs Toolpath = 4,408 lines of CNC code
    Profile - Bezier Toolpath = 2,670 lines of CNC code
    Profile - Arc Toolpath = 387 lines of CNC code
    Very impressive reductions in the file sizes when using a postprocessor
    that outputs G2 / G3 Arc moves + the some machines will also run much
    smoother using the arc based CNC code.
    Note - Converting geometry to Arcs will significantly reduce the file sizes
    of 2D toolpaths, but will not have change the VCarving or 3D engraving
    toolpaths as these have to be point-to-point simultaneous XYZ moves.
    I hope this might be of interest to other users and let me know if you
    have any questions.
    Tony
    Attached Thumbnails Attached Thumbnails Bezier_Trace.jpg   Arc_Fitted.jpg   Velocette.jpg
  1. FANUC 10M SPINDLE SPEED REDUCED
    By rchunter94 in forum Fanuc
    Last Post: 04-12-2009, 04:33 PM
  2. Reduced a lot of lathe noise tonight...
    By Jasonixo in forum Shopmaster/Shoptask
    Last Post: 04-06-2007, 07:01 PM
  3. Running reduced balls in a ballscrew
    By Corvus corax in forum Linear and Rotary Motion
    Last Post: 11-18-2005, 01:32 PM
