603,924 active members*
3,241 visitors online*
Results 1 to 2 of 2
    Aug 2010
    Berger Lahr D900.50
    Hello.
    I have some troubles with Berger Lahr D900.50 stepper motor drive board.
    The motor was running fine for some time but after weekend motor just moves back and forward. Drive board shows no error also on LED lights.
    I have 5 of those boards in my machine, I changed the position of the boards and problem goes with board. So it can't be motor fault.
    Please advise me, how could I fix the board.
    Regards,
    Marek
    Sep 2010
    i have a stepper drive d650(input voltage:70-130v,8amp max current consumption ,nominal current 2-5amp) with 5 phase motor but i continuosly gets d problem in same so which servo drive of mitshubishi make is compatible so that i can replaced?
  1. Berger Lahr 5 phases motor/driver units
    By AlainB in forum Stepper Motors / Drives
    Last Post: 01-17-2013, 11:50 AM
  2. VRDM 397/50 Positec steppers from Berger-Lahr
    By kristijan-k in forum DIY CNC Router Table Machines
    Last Post: 07-17-2012, 02:38 PM
  3. Techanical docs of Berger Lahr VRDM 564/50 LNA
    By patricks in forum Stepper Motors / Drives
    Last Post: 01-27-2010, 09:48 PM
  4. Berger Lahr
    By wanchai101 in forum Stepper Motors / Drives
    Last Post: 06-20-2008, 06:20 AM
  5. Wich Driver For BERGER LAHR
    By cor in forum Stepper Motors / Drives
    Last Post: 12-23-2007, 03:05 PM
