603,945 active members*
4,767 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Help with a Fanuc GE 0M ( milling machine 3 axis )
    Apr 2005
    8
    I have recently bought this machine ( Kryle VMC-500B ), it was made in june 1991...
    The language is in ISO and i'm trying to do some tests...
    And i am surprised to see that it didn't recognize cycles of pockets !!! ( G71 and G12 ), how i can add these functions.
    It is normal ?
    Faythfully yours
    Calor
    Dec 2003
    24260
    If I recall correctly, G71 is not valid on Fanuc milling only turning, what operation are you trying to do? and do you have the Fanuc operator manual for the OM?
    Al.
    Albert E.
    Apr 2005
    8
    I'm trying to do a rectangular pocket ( and after i have to do a circular pocket )
    No, i haven't the Operator manual af the milling, a friend tell me
    that is maybe an option or a macro to buy in supplement.
    Really ?
    Thanks for your answer Al
    Apr 2005
    23
    Quote Originally Posted by calor
    Really ?
    These functions is most likely options on your machine,most of the Cycles on the controllers is deliverd as an option by Fanuc, then its up to the machine builder on what functions they want to sell the machine with, so the cycles can vary beetween machines even if they have the same type of controller.
    So contact the maker and ask them on what cycles they deliverd your machine with as standard, if not you can always buy them from Fanuc and they will come out to you and set the parameter (expensive).
  1. Maho MH600E Milling machine questions???
    By marx911 in forum Uncategorised MetalWorking Machines
    Last Post: 01-23-2009, 07:51 PM
  2. CNC Glossary
    By cncadmin in forum Community Club House
    Last Post: 03-09-2008, 09:08 PM
  3. Why would this machine be bad for milling?
    By jevs in forum Knee Vertical Mills
    Last Post: 06-17-2005, 04:49 AM
  4. Heads Up - Article about building CNC Milling Machine
    By samualt in forum Community Club House
    Last Post: 06-13-2005, 08:43 PM
  5. which milling machine to start out with?
    By cowanrg in forum Benchtop Machines
    Last Post: 01-18-2005, 11:34 PM
