603,900 active members*
2,503 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > 72 volts through my 203V's
Results 1 to 5 of 5
    Feb 2010
    I am trying to complete my wiring diagram for my cnc kit. I have the keling 72 volt power supply capible of 20 amps. Running two three large steppers.
    When wired, my steppers have very low resistance, do I have to set a resister inline between my gecko and my motor? Does the gecko handle the proper limiting?
    Here is a (rough, incomplete but enough info) visio of what I am setting up.
    This is my first experience with steppers and I Would rather not fry anything (or everything).
    Thanks everyone
    Feb 2007
    4550
    Post
    Matt,
    The motor connects directly to the G203 with no resistors between motor and G203 drive.
    Assuming all your motors are KL34H2120 the G203 will require a 282K current set resistor attached between terminals 11 & 12.
    The current set resistor value determines the output current of the Gecko drive.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Feb 2007
    4550
    Post
    Matt,
    Don't forget a emergency stop switch connected to the G203 between terminal 7 and +5 volts.
    Jeff...
    Feb 2010
    Quote Originally Posted by jalessi View Post
    Matt,
    Jeff...
    Thank you, I was over thinking tis. :withstupi
    My estop, limit switches, and plugs arrived today from tokyo. Now we are cooking with crisco...(flame2)
    Mar 2008
    3655
    Hi Matt.
    You are using 2160 motors that are rated for 8.8A in BPP. Gecko does not recommend using motors greater than 7A with G203V. Setting for 7A is NO resistor.
    If I were you, I would give Gecko a call, just to see if the G203V will automatically limit current to 7A. If so, your torque will fall to about 1500 Oz.
    (714) 832 - 8874
    CR.
    http://crevicereamer.com
    Too many PMs. Email me to my name plus At A O L dot com.
  1. 120 Volts?
    By BrendaEM in forum Charter Oak Automation Support Forum
    Last Post: 04-09-2008, 02:24 AM
  2. THC torch volts?
    By turboboy in forum Waterjet General Topics
    Last Post: 10-06-2006, 12:41 AM
  3. 5 volts to 1.5 volts?
    By ZipSnipe in forum CNC Machine Related Electronics
    Last Post: 08-18-2006, 11:18 AM
  4. Boosting three-phase 240 Volts to 480 Volts
    By Old Car Guy in forum Phase Converters
    Last Post: 05-01-2006, 03:27 PM
  5. 24 Volts from Computer PS
    By Jason Marsha in forum CNC Machine Related Electronics
    Last Post: 01-19-2006, 04:19 AM
