587,104 active members*
4,405 visitors online*
IndustryArena Forum > MetalWorking > Moldmaking > Getting graphite molds to mate
Results 1 to 5 of 5
    May 2009
    31
    Hello, recently, I have been machining a lot of graphite molds of a bowl like shape; what would I use to "bench" the halves together? I know with aluminum, you could use prussian blue, but I don't think that this would show up on the graphite. The pieces are of a nature that they don't slide together; they mate straight face to face. When I put the two halves together, they rock a bit. I belive that the problem lies within the model itself, and not the machining; nonetheless, I need to fix it.
    Thanks in advance,
    Mark Roberts
    Jan 2010
    485
    Not real sure what you mean, pictures would help me, to help you.
    cary
    May 2009
    31
    I will try to post some pictures today....Thanks.
    Dec 2008
    226
    Just a thought to eliminate a variable...
    I'm not sure what type of machine you are using so this might be be pointless or impractical... I sometimes think outside the box...
    Try surfacing a single flat face on two pieces of stock and then mate them together, if they mate perfectly then rotate one 90 piece degrees... If they still mate perfectly then your machine should be cutting true, if they rock a little then you might have a slight twist in your machine.
    If the later is the case... and your machine has the size necessary for the movements... try rotating one half of the mold 90 degrees in software before cutting...
    May 2009
    31
    Thanks for the reply! I am running a '00 vintage HAAS VF-3, and program using GIBBS CAM. For the machining, I rough with a 1/2" ball, and finnish with a 1/4" BEM at 90 degrees to the first cut. Comparing a few measurable dimensions on the part to what the model says it should be, they were off by less than 0.0005"; I really think that the issues are within the model itself. Sorry no pictures yet.
    Mark
  1. machining graphite
    By davidsutton in forum Composites, Exotic Metals etc
    Last Post: 08-10-2016, 04:57 PM
  2. dust collection for graphite?
    By tmt_92021 in forum Moldmaking
    Last Post: 09-17-2015, 03:37 AM
  3. Graphite blocks
    By davidmb in forum EDM Discussion General Topics
    Last Post: 08-17-2015, 04:35 AM
  4. CNC Hardmilling/Graphite
    By tungwenuk in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 02-21-2010, 06:51 PM
  5. EDM Blanks Graphite
    By SPEEDY1977 in forum Waterjet General Topics
    Last Post: 02-09-2007, 08:35 PM
