Well as my bad luck would have it at me again.
I accidentally fried something. Stupid me took to front cover off with the power on. (Not think when i did it) It sparked. The stupid quil dro hit the board. I can see a chip on the board is missing a chunk out it. When i plug it all back in everything lights up. Stop and start work all the buttons work lcd works. But spindle don't run. In cnc mode or manual. And mach 3 says e-stop active and will not come out of as long as the machine is on.
Did i just mess up that board? Or did i do more then that?
Help me please.
edit
Would not had to take the cover off if the cnc mode switch was properly soldered together. The wires shacking around on the switch is what was causing an early problem i was having with Erratic Spindle rpm's.
