603,996 active members*
3,515 visitors online*
Results 1 to 1 of 1
    Apr 2006
    38
    Bridgeport Atom PC
    I just finished testing my new Mach 3 driven Atom PC. It works great!
    I've been using a standard PC, Derek's (Hillbilly) breakout board, and Mach 3 on my mill for sometime. Last month my PC took and dive so I decided to try something different. Previously, I had the PC mounted in the side cabinet and I noticed a lot of vibration during heavy machining. PC circuit boards do not like this and indeed my motherboard is what ended up failing.
    The Atom motherboard is only 7 x 8 inches. I have an ASUS AT3GC-I. My total enclosure size with hard drive and CD ROM is only 5 x 9 x 13 inches. I got all of the stuff online. The MB, Case and RAM only cost $190. I used the old hard drive and CD ROM.
    In the photos you can see that I have a bracket on the side of the mill that contains the PC box and a mount for the monitor. The monitor mount is adjustable. I also have a swiveling pan for the keyboard.
    Hopefully someone gets an idea from this for their own MOD!
    Attached Thumbnails Attached Thumbnails mill-PC-mount.jpg   mill-PC-front.jpg   mill-PC-rear.jpg
  1. Bridgeport DNC
    By hmc710 in forum Bridgeport / Hardinge Mills
    Last Post: 02-09-2010, 01:14 AM
  2. Bridgeport 760-20
    By Richmaj in forum Uncategorised MetalWorking Machines
    Last Post: 08-24-2009, 08:21 PM
  3. Bridgeport INT 412
    By Jurek in forum Want To Buy...Need help!
    Last Post: 04-07-2009, 04:35 AM
  4. Atom Minor Mk III
    By dcencer in forum I.C. Engines
    Last Post: 08-20-2007, 01:22 AM
  5. Which Bridgeport would you buy?
    By Skyshark in forum Bridgeport / Hardinge Mills
    Last Post: 08-18-2007, 05:32 AM
