603,942 active members*
2,958 visitors online*
Results 1 to 3 of 3
    May 2010
    Smile A2918SW circuit
    Hello eveyone
    first I would like to thank you all for the help you are giving and the support
    now my problem is
    I have a broken copier machine so I thought to get the motors and drivers from it
    the driver board that used in the machine is using the A2918SW drive IC
    I want to know how can I take this a part and use it to control the stepper motor from the parallel port of my pc
    I am using mach3 for controlling
    as I know the 2-9 data can be used in the port but where it should go on the IC?? to what pins?
    what is the voltage to operate the IC and if there is a circuit diagram to the IC? not the internal diagram but the full opreating diagram.
    please help me on that.
    thank you all in advance
    Jul 2007
    78
    Hello dude.
    I just find in the same situation since last month i gott the same printer machine and the same board.
    Wait a week and i will try to figure it out.
    Should be not to dificult to use it.
    You are planing to use the motor wich came pluged to the board?
    I didnt like it too mach. May be i will look to set up for more powerfull motors.
    The schematic of a2918 suggest a peak current of 1.5 amps, and that should be enough for good torke results.
    Chears.
    See you next week.
    Mar 2009
    4
  1. led in circuit
    By graphpix in forum CNC Machine Related Electronics
    Last Post: 10-28-2012, 07:55 PM
  2. Shunt circuit
    By fahque99 in forum CNC Machine Related Electronics
    Last Post: 08-05-2009, 05:54 AM
  3. Dump circuit
    By Pbrew1 in forum Servo Motors / Drives
    Last Post: 07-25-2006, 05:15 AM
  4. Circuit Help
    By Shanghyd in forum CNC Machine Related Electronics
    Last Post: 09-16-2005, 02:02 PM
  5. Circuit needed
    By jimini in forum DIY CNC Router Table Machines
    Last Post: 09-05-2003, 02:06 AM
