587,187 active members*
4,499 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Anyone willing to take a look
Results 1 to 2 of 2
    Jul 2008
    85
    So I hate to ask for help..I really try to figure stuff out on my own.
    Anyway some info. Running X3
    I normally do 2d designs and such. This is the first part that I have a 3d solid model for.
    First op: It is laying flat and doing the top face, drill holes, outside profile, lower step.
    Second op: it is set at a angle and faces the angle and drills the ball endmill indents.
    I can not get it to chain the pocket so i can cut it.
    I get a boundary does not lie in construction plane message. I cant figure it out.
    I'm still fairly new with mastercam. The model i designed in ironcad while in class at school.
    I can email a file to someone if any body is willing to take a look.
    Nick
    I Know I Cant Spell..Don't Remind Me
    Dec 2008
    717
    Make sure that your wcs planes are "true" to the pocket (as in - the pocket chain is actually at a constant -Z- depth)...otherwise you have to use 3D when you are chaining it, and the -z- will follow accordingly.
    If you analyze the pocket chain and the Z is the same at every point, then something else is amiss...
    If you want to PM me and send over the file I can take a look for you.
    Tim
