587,626 active members*
3,056 visitors online*
Results 1 to 14 of 14
    Aug 2012
    Unhappy I Need Help. CNC not moving.
    Hi good day CNC Zoners. First of all, I wasn't really sure where to post this thread so decided to post it in here. MODs are welcome to move it where it belongs. I am a newbie on CNC and bought this cheap CNC thru ebay ( CNC 3040) Now I can't get it to work. I have no idea how I am going to troubleshoot this machine. I'm thinking of lots of factor that might be the problem with this. First, If I installed the software right. Is the Parallel adapter working? The cnc axis controller isnt working? Motors not working?
    So first, I have freshly installed Windows XP on my computer and connected everything as what it says on the maunual. After testing it out, none of XYZ is moving. Tho, the spindle is working if you control it manually on the CNC controller. I set everything correctly on the Mach 3 software includng the port number. Then after, I connected the parallel port and the USB cable. It's still not working. I even tried to use two different computer and even, an old Dell laptop just to try my luck, but all didn't work out. I also tried re-installing everything and all didn't work as well. I also check the hard ware on device manager and it says that it is working fine. Lastly, it seems that the XYZ motors are locking up once I turn the driver switch on. is that normal? Can you please help me out with this? Thank you.
    Jul 2009
    690
    What kind of parallel port are you using?
    - If it's built in the motherboard it should work fine.
    - If it's a PCI add-on board you might need to check the card address at the device manager (it can be different than the default address).
    - Parallel to USB adapters will NOT work.
    Aug 2012
    It's an add-on adapter to my z68 and z77 boards. In device manager there are two addresses. One time it was
    IO - E010 - EXXX
    IO - E000 - EXXX
    So at config of Mach 3, I put 0xe010 on the first adapter and it still didnt work. I even tried enabling the 2nd adapter putting both 0xe010 and 0xe000. Still can't get it to work.
    Jul 2009
    690
    Did you configure the output ports as "1"?
    Is the E-stop working, or at least emulated so you can disable it? (the motors won't move while E-stop is active)
    Can you post some screenshots of the ports and pins config windows?
    The motors locking up when powering up the drivers is normal, it's a good sign.
    Aug 2012
    Sure. Give me time, It's on a different computer. I'll show you everything.
    Aug 2012
    Here are the screenshot of the system and the configurations.
    System:
    http://i49.tinypic.com/2lkplcj.jpg
    Configs:
    I followed everything it says on the manual which it came with package.
    Feb 2011
    91
    You have the 3 drivers set to use the same pins. Usually is 2and 3 for x 4and 5 for y and 6 and 7 for z. What u need depends on how it is actually wired. I have the 6040 machine like yours and that is as i said.
    Step port and direction port. There is no port 0 it is 1 or 2 set them to port 1
    Go to the mach site and there is a getting started guide in the support documentation page. This outlines it all quite well
    35538
    In addition to setting the pins to port 1, try entering just E010 for Port 1, and disable Port 2.
    Jan 2008
    940
    Have you checked that the parallel port is actually working.
    Aug 2012
    It's working now. Thanks everyone!
    Jul 2009
    690
    That's good to hear, enjoy your new machine
    Nov 2018
    Re: I Need Help. CNC not moving.
    Hello,
    I am having the same problem with a CNC 3040T, the X,Y,Z wont move when I give the command on mach 3 Demo. I tried fixing the pots but nothing works. I am using a USB adapter not the parallel cable.
    How did you fix the problem?
    Thank you.
    Jan 2021
    12
    Have you set the port to 1 and the pin out correct like above?
    unless there set correctly youve no chance mate.
    Dec 2003
    1236
    Since he hasn't posted about the problem since 2018,there is a strong chance that he overcame the problem.
  1. Design Options: Moving bridge vs. Moving Cross Beam
    By martin_05 in forum Mechanical Calculations/Engineering Design
    Last Post: 04-22-2014, 08:20 PM
  2. Moving table vs. moving gantry for routing PCB's?
    By zephyr9900 in forum DIY CNC Router Table Machines
    Last Post: 10-25-2013, 06:45 AM
  3. Trade offs between Moving Gantry and Moving Table
    By gregmary in forum DIY CNC Router Table Machines
    Last Post: 04-22-2011, 07:48 PM
  4. Discussion of moving table vs moving gantry
    By rkremser in forum DIY CNC Router Table Machines
    Last Post: 02-20-2008, 10:59 PM
  5. Moving Table vs Moving Gantry; Dremel vs Router
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 03-28-2007, 02:48 AM
