What size drills are you planning on using? We use the shank type collet holders ER25 and ER16 for small drills. We also use straight boring holders with a bushing for larger drills up to 1" with 1/2" shanks. I have also made custom gang type tool holders for spot drill, drill and tap to reduce the number of tool changes when tapping small threads in small diameter round bar. I have also made custom holders that use 5C collets and R8 collets for drills and taps.
