Hello
First post here.
My shop just bought a used 1998 VF2. The machine was set up with 3 phase 480v input power. We have 3 phase 240v power. I am trying to find out if I can just swap to the low voltage, 190-260v transformer, swap the internal breaker and wiring to the transformer to 50 amp capacity and run it. I had considered just bypassing the transformer but my shop power is slightly higher than the 230v input to the Vector Drive and it has a crazy high leg that reads 200-215v to neutral depending on the time of day.
The only place besides the transformer that sees line voltage is the P1 plug on the circuit board on the Power Assembly Panel which I was told by a couple people is for phase monitoring only but I don't know.
Any idea If I can just swap transformers and internal breaker and run this and where I can get a low voltage transformer?
Thanks in advance.
